1.0 Ecoboost timing belt replacement
7 hours ago, dontpannic said:
All pre MY19 1.0 Ecoboost engines are "wet belt"
Except the Focus Mk4 (2018) which was launched with the revised 1.0 Ecoboost engine. Only the 2.0 Ecoblue Focus Mk4 continues to use the wet belt (ask me how I know 🙄).
  • Replies 138
  • Views 328.3k
  • Chances of it having been done is almost zero. If it had of been the seller would have made a point of telling you. If you get Ford to do the work expect to pay £1450 to £1800 !!!! Some specialis
  • Changing the wetbelts on a 1.0 ECOboost is a major job. It will take an experienced mechanic approximately 12 to 16 Hours to perform this job the 1st time. Changing the wetbelts basically cons
  • Yes 🙁 Yes 👍 but it might not last a full 11 months 🙁 People think that they have to wait for the 10 years before they change the belt. It is very important to realise that 10 years is the
On 2/2/2024 at 7:54 AM, MJNewton said:
 I suppose in theory there might well be differences between manufacturers but I haven't seen any commentary on that point and given the long interval time between installation and eventual failure we might never know.
I agree. I currently have a BGAutomotive belt fitted but there is no real way of knowing how it's performing without significant work.
Previously used a Dayco belt (supposedly the same as that supplied to Ford). Wasn't happy with it's condition when exposed early due to other issues.
Are other brands more durable?
Durex are known to make durable rubber products 🤣
For example continental belt, is it more durable? Or other brands?
Re better materials.
As many of you are aware, Citroen/Peugeot suffer from wet timing belt problems.
Back in 2020, Continental claimed that they had further improved the belts for their 1.2 engines:
20200625_PR_Continental_NewBelt_CT1228_EN.pdf
Carbon cleaning or fuel line cleaners could affect the timing belt (degrade it)?
yes - they need a specific oil that is kept in tip top condition to reduce belt deterioration ANYTHING that moves away from 10 mile drive every time, start stop turned off permanently, and Ford Spec Oil changed comfortably inside service schedules will impacted things negatively.
any fuel additive or cleaner is a lottery - I was reading, even a can of cleaner said change the oil after using it (and that was for any car, not sensitive ones)
this comment below is not 'suffering from' - its 'performing exactly as designed', increasing profit for the manufacturer as implemented by the engineering team and the accountants
Quote
do as your are told and hand over your cash - its across all aspects of society as created by the evil scum....
So fuel line cleaners could impact and even 100 octane petrol.
Considering that Peugeot recalled vehicles for this exact issue and offered longer warranties - in effect fronting the cost themselves for belt replacement suggests that this comment is incorrect.
Apparently the disintegrating belt affected the vacuum pump:
https://car-recalls.eu/peugeot-citroen-1-2-puretech-brakes-booster/
It does on ecoboost too, I believe
and that shows you don't understand the scale manufacturers work too
yes sure they pushed 'this win' a little too far - and 40% of the savings got lost on warranty repairs and unraveling the mess... but they are still a few hundred million up by introducing rubbish...
that got the management team a bonus payment they were after - and any damaged reputation is in today's world utterly irrelevant - slaves on forums in the know trying to help others in the pigswill at the bottom don't matter... the bent marketing team will copy someone else's strategy that'll get more idiots from middle management buying joke rubbish these corporations peddle
why do you think BM Merc VAG are the biggest sellers and growing market share hand over fist - its not the quality or longevity of the products - if the people that have these car's had the ability to understand what they are contributing to, like
wasting world resources
climate damage
enslavement of the majority
societal downfall
zero future for their genetics
they would still likely do it !!! for the short term monetary gains they are already receiving - because that's why they are the managers - they were cherry picked because they are stupid lemmings that are corrupt and incompetent - which is exactly what the ones at the top need - to get away with what they are doing (which is that same list - except: they have been told they have been put at the top of the list of your genetics will get looked after....)
youngsters and fools should review the three programs on the miners strike Ch4 just did - think bigger picture of why its got the programme title it has...
https://www.channel4.com/programmes/miners-strike-1984-the-battle-for-britain
That is exactly how Ford have always operated
I'm not familar with the Puretech issues (I've read quite enough about the ecoboost without delving too far into that one!). I wonder if it's a case of belt debris affecting the vacuum pump first, before it can clog up the oil pump and destroy the engine through lack of oil pressure.
I suspect it is not so much a case of it necessarily occurring first but rather the fact it might happen at all. More specifically, brake failure is considered an unequivocal safety issue (hence the recall being a safety recall) whereas DVSA have stated on a number of occasions (in the context of coolant and wet belt related Ecoboost issues) that engine failure in and of itself is not considered a safety issue.
405201162_10231673994410059_7343015159458271924_n.thumb.jpg.a0201cbe3f25711ebe3b0adfbd528861.jpg
And yet we know it does occur in the ecoboost and is mentioned as one of the reasons for the major recall in the US (though that is, so far, for engines with balancer shaft).
https://www.thedrive.com/news/fords-self-clogging-1-0-liter-ecoboost-engine-is-finally-getting-recalled
Yeah, there doesn't seem to be all that much consistency really. Perhaps the ramifications of a potential safety recall affecting millions of cars is just too big to ignore hence why there is seemingly so much reluctance by anyone to go down that route. To be fair it isn't a decision to be made lightly!
australia had a very healthy get the corporations for peddling rubbish - but that'll soon be history since the french sub episode got them back on the dark side
remember back to the powershift car crash of a gearbox - they all had a new clutch and gearbox...
https://www.productsafety.gov.au/products/transport/cars
Hmmm. Just for fun I put "Peugeot Puretech engine problems" into my usual search engine - 365,000 results!
100 octane petrol could impact the timing belt?
I doubt it
But fuel line cleaners like wurth could impact it correct?
100 octane has some additives though.
I doubt both, unless you're massively over fuelling and suffering from bore wash
Thank you.
