Focus7788 Posted October 1, 2020 Share Posted October 1, 2020 Hi guys, so I changed the fuel filter today. Pretty ***** job, bled the air at the injectors and it started quite easily. But then I went to change my cigarette lighter fuse as I use bluetooth transmitter for music. While changing it I saw the ignition switch fuse just had a wire stuck into it instead of a fuse so I pulled that out and put proper fuse in. Now car won't crank, very strange and immobiliser light keeps flashing. Thanks guys Quote Link to comment Share on other sites More sharing options...
Focus7788 Posted October 1, 2020 Author Share Posted October 1, 2020 When I took out fuse 67 (alarm and instrument panel) it started cranking but didn't start though. Strange Quote Link to comment Share on other sites More sharing options...
Focus7788 Posted October 2, 2020 Author Share Posted October 2, 2020 Sorted!! Delighted 😊😊 Still have 2 fuel codes though but at least it started and moved Quote Link to comment Share on other sites More sharing options...
Frowma Posted October 2, 2020 Share Posted October 2, 2020 3 hours ago, Focus7788 said: Sorted!! Delighted 😊😊 What was the fix? Just curious like. Quote Link to comment Share on other sites More sharing options...
Focus7788 Posted October 2, 2020 Author Share Posted October 2, 2020 2 hours ago, Frowma said: What was the fix? Just curious like. Downloaded an app to use with elm327 and read codes and a code read attempted theft. App is Carbit Cleared the codes and it started straight away. Not sure if it's a permanent fix but I've been on a 5 hour journey today and cars working fine. 1 1 Quote Link to comment Share on other sites More sharing options...
