Leak in roof.
I have a 2004 Street Ka. In heavy rain there is a build up of water in the drivers footwell..
Is there any remedy,or is this just one of those things one has to accept with soft top`s?
I can't imagine this is something you ought to simply 'accept'.  I would recommend locating where the leak is coming from- Check the seals running between the top and body and identify where any pools of water are gathering. If there is a gap or a tear, you could repair this will a rubber sealant or fabric. If there are no gaps, consider waterproofing?
Also if you're getting water in the drivers footwell, I would keep an eye on the state of your floor for corrosion/rust.
Good luck!
