Jackhynes Posted July 12, 2021 Share Posted July 12, 2021 Hi guys I have a 2008 Ford s max I replaced my steering rack but now my steering wheel is half a turn off centre how do I fix this or can a tyre shop fix it for me ? thanks Quote Link to comment Share on other sites More sharing options...
unofix Posted July 12, 2021 Share Posted July 12, 2021 The quickest way is to take the steering wheel off and put it back on in the correct place. Disconnect the battery first. Then remove steering wheel airbag (be gentle) undo the nut holding steering wheel on, and the pull the wheel forward to remove it. Reposition the wheel and put it back on. Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted July 13, 2021 Share Posted July 13, 2021 Have you had an alignment done since you replaced the rack? The garage should've set the steering wheel to the centre before adjusting the track rod ends. If you haven't had an alignment done then you'll definitely need one. 2 Quote Link to comment Share on other sites More sharing options...
Paulkp Posted July 18, 2021 Share Posted July 18, 2021 And the length of the track rods should be the same on both sides. Quote Link to comment Share on other sites More sharing options...
