alanfp Posted November 28, 2021 Share Posted November 28, 2021 I have a 2013 estate. My number plate bulb intermittently fails (no apparent pattern) so I want to replace it. Youtube tells me that I need to remove tailgate handles, then inner plastic trim, then outer horizontal trim in order to get to the combined lamp/switch unit. Is that all actually necessary or can it be removed from the outside by prising it downwards??? Thanks. Quote Link to comment Share on other sites More sharing options...
unofix Posted November 28, 2021 Share Posted November 28, 2021 Hi Al, the quick answer is YouTube is correct. I have seen people use an old credit card to slide between the edge of the handle and the body to push back the spring clips but I can't say that I've tried. 1 Quote Link to comment Share on other sites More sharing options...
alanfp Posted November 28, 2021 Author Share Posted November 28, 2021 Thanks Uno. That idea has really helped me! I used two credit cards (at the same time) on the long edges to remove the outer bits and then used a flat bladed screwdriver to attack the short edges on each side to prise away the spring clips. Worked a treat - about ten minutes start to finish! 3 Quote Link to comment Share on other sites More sharing options...
alanfp Posted December 9, 2021 Author Share Posted December 9, 2021 Quick update. The outer lens and trim parted company with the innards when I prised it out, but that doesn't matter, as I was replacing the whole unit. I paid £11 (plus P&P) for a generic part rather than the £63 that Fraud wanted. Fitted it today (in 5 minutes). Time will tell whether it's as good as a genuine part..... Quote Link to comment Share on other sites More sharing options...
alanfp Posted December 16, 2021 Author Share Posted December 16, 2021 On 11/28/2021 at 5:22 PM, alanfp said: Thanks Uno. That idea has really helped me! I used two credit cards (at the same time) on the long edges to remove the outer bits and then used a flat bladed screwdriver to attack the short edges on each side to prise away the spring clips. Worked a treat - about ten minutes start to finish! Further update X 2.......... 1. On re-reading my previous post, I realise that I may not have made myself clear - I used two credit cards and a flat-bladed screw driver to prise out the LAMP from the outside, not the covers of the inner handles. So to be clear, contrary to the YouTube video that I found, there is no need to remove any trim or handles. 2. The replacement (non-Ford) lamp unit works fine, but weirdly, once I've locked the car, the lamp stays on dimly (about 10% brightness) for 5-10 minutes before turning off completely (around the same time as power to the cigar lighter cuts off, perhaps???). Quote Link to comment Share on other sites More sharing options...
