gem module
I had exactly the same corrosion as the foto of tdci-peter cleaned all but same result, nothing.
  • Replies 53
  • Views 20.4k
  • This morning received a 2 hand Gem module, configurate, reprogrammed and......yes it works all 😀😀😀😀😀 Thanks everybody for your support and help.
  • A bit of confusion is going on here, I think. PATS is in the cluster (IPC) If the ignition is working and the engine is starting then you don't need to and shouldn't be deleting keys. R
  • the 80 bits came from model 2010 so my key will have a 40 bits transponder.
GEM is damaged then.
Source and program a new/2nd hand GEM
Excellent, now protect it from the obvious water leak you have
