nivek24 Posted February 8 Share Posted February 8 Morning, my son bought this 2021 Kuga 1.5 ecoboost and was told by the Ford garage he bought it from that it needed oil changing every 2years with 0 -20w oil. We have just done a service on it at 31k and the oil was really black. Put new oil in Magnetic 0-20w and is black again straight away. Can the oil grade be changed to a lower spec and changed every 12months , i think the 2years sevice life of the oil is a bit too long. I have an old Mondeo 2Lr diesel and change the oil every 6 months regardless of mileage, it never gets black and thick like the 0-20 was, thanks Kev Quote Link to comment Share on other sites More sharing options...
DaveT70 Posted February 8 Share Posted February 8 I would only use recommended oil, change at the recommended time or sooner 1 Quote Link to comment Share on other sites More sharing options...
nivek24 Posted February 8 Author Share Posted February 8 ok thanks Dave. Quote Link to comment Share on other sites More sharing options...
RL123 Posted February 8 Share Posted February 8 2 yrs or 18k is the recommended service intervals or sooner if the vehicle or app flags it up. No harm in doing it more often but stick to the correct oil and no use of flushing oil (wet belt oil pump drive) Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 8 Share Posted February 8 Are you sure it's a 1.5 EcoBoost? Not a 1.5 diesel? 2 Quote Link to comment Share on other sites More sharing options...
alexp999 Posted February 8 Share Posted February 8 1 hour ago, TomsFocus said: Are you sure it's a 1.5 EcoBoost? Not a 1.5 diesel? That would explain the instant colour change. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 8 Share Posted February 8 37 minutes ago, alexp999 said: That would explain the instant colour change. And the 0-20 spec. I'm fairly sure the petrol spec was 5-20. 1 Quote Link to comment Share on other sites More sharing options...
Eric Bloodaxe Posted February 8 Share Posted February 8 12 minutes ago, TomsFocus said: And the 0-20 spec. I'm fairly sure the petrol spec was 5-20. Yes, 5-20 for the petrol, for the diesel the manual says: Materials Name Specification Ford-Castrol Magnatec WSS-M2C952-A1 Which is: Ford-Castrol MAGNATEC 0W-20 Diesel 1 Quote Link to comment Share on other sites More sharing options...
nivek24 Posted February 9 Author Share Posted February 9 Yes, it is a Diesel, Is this the dry cambelt and wet oil pump belt then. I thought these had problems ? Quote Link to comment Share on other sites More sharing options...
unofix Posted February 9 Share Posted February 9 On 2/8/2024 at 11:45 AM, nivek24 said: my son bought this 2021 Kuga 1.5 ecoboost Petrol engines with a turbo are Ecoboost Diesel engines with a turbo are Ecoblue. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 9 Share Posted February 9 1 hour ago, nivek24 said: Yes, it is a Diesel, Is this the dry cambelt and wet oil pump belt then. I thought these had problems ? That'll be a 1.5 EcoBlue then. 0w20 oil and 2 yearly or 18k mile services. No wetbelt at all on these. oil pump is driven directly from from the crankshaft. Dry cambelt interval is 10 years or 120k miles. Diesel oil always goes black. But 2 years is generally too long for oil in this engine. It uses an intelligent oil quality sensor that should detect when the oil actually needs changing. Make sure that has been reset correctly after the oil change. 2 Quote Link to comment Share on other sites More sharing options...
DaveT70 Posted February 12 Share Posted February 12 On 2/9/2024 at 7:49 PM, TomsFocus said: That'll be a 1.5 EcoBlue then. 0w20 oil and 2 yearly or 18k mile services. Focus with the 1.5 Ecoblue is 12 months 10,000 ,miles, has something changed? Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 12 Share Posted February 12 2 hours ago, DaveT70 said: Focus with the 1.5 Ecoblue is 12 months 10,000 ,miles, has something changed? When they introduced Adblue in 2020 the interval changed from 12m/10k to 24m/18k. Adblue means less EGR use. Less EGR use means less soot in the DPF. Less soot in the DPF means fewer regens. Fewer regens means less oil degradation. That's the theory anyway... 2 Quote Link to comment Share on other sites More sharing options...
Emeraldgreen652 Posted February 17 Share Posted February 17 On 2/8/2024 at 2:59 PM, TomsFocus said: And the 0-20 spec. I'm fairly sure the petrol spec was 5-20. My 1.5 180 Kuga AWD Automatic has the oil cap 5w-20 but i only have the oil belt as a wet belt. However i believe that its so 'watery' for a turbo engine, i would prefer the 5w-30 oil for more protection.. Quote Link to comment Share on other sites More sharing options...
Emeraldgreen652 Posted February 17 Share Posted February 17 On 2/8/2024 at 11:45 AM, nivek24 said: Morning, my son bought this 2021 Kuga 1.5 ecoboost and was told by the Ford garage he bought it from that it needed oil changing every 2years with 0 -20w oil. We have just done a service on it at 31k and the oil was really black. Put new oil in Magnetic 0-20w and is black again straight away. Can the oil grade be changed to a lower spec and changed every 12months , i think the 2years sevice life of the oil is a bit too long. I have an old Mondeo 2Lr diesel and change the oil every 6 months regardless of mileage, it never gets black and thick like the 0-20 was, thanks Kev Re oil being changed every two years! wow years ago servicing was done every 9,000 on average, but even fresh oil get black and 'watery' after a few months, Can Castrol really say that their oil is still at Spec and protecting an engine past 24 months?? Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 17 Share Posted February 17 1 hour ago, Emeraldgreen652 said: My 1.5 180 Kuga AWD Automatic has the oil cap 5w-20 but i only have the oil belt as a wet belt. However i believe that its so 'watery' for a turbo engine, i would prefer the 5w-30 oil for more protection.. Turbo bearings have become smaller over time. The gap between the brass bush and the turbine shaft may not be large enough for 30 weight oil to penetrate effectively when warm. I really wouldn't risk a thicker oil in an EcoBoost engine myself. oil tech has come a long way since the 70's. It's fully synthetic nowadays with various additives to prolong it's life. Plus engine components are often coated with Teflon type material to reduce friction. Servicing is designed as a compromise between excessive cost, wasting resources and the realistic longevity of a vehicle/engine. 2 yearly servicing should see the engine last the expected 10-15 year life. Quote Link to comment Share on other sites More sharing options...
unofix Posted February 17 Share Posted February 17 10 hours ago, Emeraldgreen652 said: However i believe that its so 'watery' for a turbo engine, i would prefer the 5w-30 oil for more protection.. Yes, Ford have no idea about what is required for the engines they design and test. You're better to just put in what every oil you think will be best. Just don't be surprised if the engine fails due to lubrication problems. 🤔 Quote Link to comment Share on other sites More sharing options...
