Aircon service
27 minutes ago, captaincadet said:
Your right… the condenser on front of the car is the highest pressure part of the whole system? As the note I took was on the phone was:
low pressure side condenser
low pressure pipe to condenser
low pressure seals
Yes.  The low pressure side is between the evaporator (under the dash) and the compressor.*
But it doesn't matter what they called it as long as they've found the leak. :smile:
*AC Process is fairly simple if you were good at GCSE physics.
Start with low pressure gas.  Squeeze that in the compressor, creating high pressure gas.
Cool that in the condenser, creating high pressure liquid.
Evaporate that into a low pressure gas inside the evaporator.  This change of state from liquid to gas creates the cooling effect we are after.
Return that low pressure gas back to the compressor to start the cycle again.
  • Replies 64
  • Views 12.5k
  • StephenFord
    StephenFord
    Book into an independent A/.C guy. They'll fill the system with a UV dye which will help highlight where the leak is. Once that is determined, then you can go from there on how much a repair will cost
  • captaincadet
    captaincadet
    True I’m just worried they’ll be unable to work out what’s leaking
  • Super Seal Air Con Leak Sealant - For Gas R1234YF  ---- £29.99 An Aircon specialist should be able to use a sealant in with the gas if you are talking about pin hole leaks.
My A level physics teacher would be very proud of you!
Right. I’m even more confused now as they said if it was on the high pressure side it would have emptied much quicker.
Ive had a look at the AC system from the outside and I cannot for the life of me see any dirt or anything that might show where it’s leaking.
Goodness me... I said, right at the start, a proper A/C guy would full the system with a UV dye so it could instantly be a visual indicator where it was actually leaking!! All you're doing is sticking your finger up in the air and guessing where it's all gone 🤣 That is no way to diagnose a fault...
Yes i appreciate that - thought I would just look to see whether anything got pushed out yesterday and tried with a UV torch
while sure they seemed to have found the right area for the leak, I’m not fully convinced with their explanation which probably why im still looking for it. I suspect it might be a good idea for me to potentially find someone else to look at this?
1 minute ago, captaincadet said:
... I suspect it might be a good idea for me to potentially find someone else to look at this?
What, you mean like a guy that specialises in A/C repairs?? Better hurry, once the warm weather hits, they'll be swamped 😂
I mean the garage I did go to did advertise themselves as a ac specialist…
If they also 'fix' cars, that's not an accurate statement...
This is an A/C specialist, I'm sure Wales has some too...
I appreciate they however local AC garages to me also all appear to do other car repairs. There are some travelling ones that only do AC  however they only appear to use sealants.
Air con systems come with a dye from  new so any leak really should be visible even leaking for 6months. A good UV light and glasses should be sufficient to source the leak. 2 main leaks are normally condenser and main pipes where they join the condenser( o rings)
Yes it seems like that - spoken to another garage and they said it wasn’t worth attempting to diagnosed it if you know it’s coming from the front end as such a slow leak in their experience is the condenser or O rings
  • 1 month later...
As promised here’s an update. Managed to get a new condenser into the car for £450 and regassed. No leaks were showing and the ac while has gone away.
We never found the source of the leak in the end but this garage was certain it was the condenser as they seen a few Ford with the same grill as mine come in with damage as it’s so exposed.
Crikey, £450? I struggled to find one (new) on Ebay for any more than £100. Still, if that's you back up & running, well done...
It also included new pipping and dryer and the cost of the gas refill and labour.
it works out cheaper than what the other place quoted and while I may have gotten it cheaper it was done at a garage that I trust
the piping is extortionate had to have mine done as the union failed
