Ford Focus mk3 1.0 125ks
Did you say to them the vin code?
  • Replies 119
  • Views 9.3k
  • TomsFocus
    TomsFocus
    That cap is broken.  Half of it is stuck in the bottle.  Just need to fit a new one. As for taking to sea, I'm not sure how buoyant the Mk3 Focus is.
  • A local Ford service centre will be able to tell you if any recalls have been done. You need to confirm if the wet belts have been changed, if not, you need to budget to get them done ASAP D
  • Everything looks and sounds perfectly normal to me. These high pressure fuel pumps do become noisy as they are driven mechanically off the inlet camshaft via a tappet.  On my Focus there is
2 hours ago, Bol said:
Да ли си им рекао вин код?
Yes
  • 2 months later...
Can you tell me which diagnostics to buy for my car.
The simplest is to buy an OBD reader - Bluetooth. It can be connected to phone. Download Torque Pro application.
Otherwise Forscan in a laptop computer with a special wire that it can be connected to OBD.
FORScan is the best by a long way, either the Phone or the Laptop version.  https://forscan.org/download.html
Otherwise Forscan in a laptop computer with a special wire that it be connected to OBD.
which obd do you think i should buy, is it possible for you to write or send me a picture. I had ELM327 version 1.5 - WORKS but it says not for my car, so I wanted to buy another one, which is compatible with my car, can you tell me which one to get
Did you test it with torque pro?
I used forscan on my laptop, I need a new version. I don't know which diagnostics to buy.
You have already been advised to use FORScan which is free and which you say you already have on your laptop so why would you want to pay for something that won't be able to read all Ford codes on both the HS and MS can buses? You won't get anything better. If you're saying you have an old version of FORScan just download the latest version.
Everything a Ford owner will need for diagnostics:
On 4/7/2024 at 8:59 PM, unofix said:
FORScan (for use with Windows Laptop) : https://forscan.org/download.html
It's what many Ford owners use including some Ford technicians.
vLinker FS, cable for laptop: https://www.amazon.co.uk/Vgate-vLinker-Adapter-FORScan-MS-CAN/dp/B0952P4MLP
vLinker FD, for android phone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H82WC8L
vLinker FD+, for iPhone: https://www.amazon.co.uk/Vgate-Bluetooth-vLinker-Scanner-Diagnostic/dp/B08H8JHWP2
forscan is ok, but I think the device is not ok, I used this one, I think I should replace it and get another one. It opens everything for me, but before that it tells me that it is not the device for this car
If you read my post above then you will see the link for the correct lead to use.
Try the links above.
All the information required is written in this topic.
You are correct. That lead is not capable of switching between the two different can buses. You need the one suggested by @unofix above.
thank you very much, now I see sorry, only if I can find it in my country, because I can't order from amazon in my country, I can only order from aliexpress and ebay
do you know any link from aliexpress or ebay for ordering? Send me the device link, if anyone uses ebay or aliexpress
UK eBay: https://www.ebay.co.uk/itm/225681548493?
UK OBD2 Shop: https://www.obd2shop.co.uk/wholesale/vgate-vlinker-fs-elm327-for-ford.html
UK Tunnelrat Electronics: https://tunnelrat-electronics.fwscart.com/product/vgate-vlinker-fs-usb
Probably best if you do not buy from Aliexpress, they have a lot of fake products.
thank you, I will order this one on ebay, I don't know if they send from your country to Sebia?
can the mileage be checked through this diagnostic or is a special diagnostic required
Yes it will show the vehicles mileage or in kilometers.
Can I suggest you amend your profile to show you don't live in Kent, UK?
Also it would be much easier to read your posts if they were not in inverse video. On my browser they show as grey text against a black background.
Personally I would avoid this Ebay seller. Although they claim the item is located in Manchester, UK they are in fact based in China. The item may be genuine or a Chinese fake. However it's your choice.
I believe Tunnelrat test all their cables before dispatch (at least they used to do so unless anyone knows otherwise).
I made changes to my account, if something else needs to be changed, please let me know. Now I don't know what to do with ordering on ebay?
Still inverse video. I doubt it's my browser as I don't experience this with posts from other members. It would be interesting to know if others on the forum are seeng the same as me. Maybe one of the moderators knows what needs to be changed.
Are you using a translator ?
If you are copying and pasting text from a translator like Google it can cause it to invert the video.
Само тестирам да видим да ли је видео обрнут
5 hours ago, unofix said:
Користите преводиоца ?
Ако копирате и лепите текст од преводиоца као што је Гоогле, то може довести до инвертирања видеа.
Yes bro , google translate
Text is now normal.
Have you changed something ?
22 hours ago, unofix said:
Text is now normal.
I wrote the previous post by myself, without google translator 😁. Now I'm logged in and using google, it seems that when I copy, the background is black, but I can't change it
