Niru Posted March 30 Share Posted March 30 I have very recently (5th March) purchased a Ford fiesta Titanium Ecoboost. So have a lot to still learn. So sometimes the Miles left indicator increases instead of decreasing. For example, driving home today the 321 miles was indicated. When I got home, 331 miles! How can that be? Many thanks. Quote Link to comment Share on other sites More sharing options...
unofix Posted March 30 Share Posted March 30 Just now, Niru said: Miles left indicator increases instead of decreasing. Correct. 馃憤 The ESTIMATED range is based on the past 100 miles of driving and is projected forward as a "best guess" If in the last 100 miles you have been driving hard, or stuck in slow moving traffic then the car will have used a lot of fuel. If now you are doing some easy steady driving and making good steady progress then the car will be using less fuel. 3 Quote Link to comment Share on other sites More sharing options...
Niru Posted March 30 Author Share Posted March 30 Thank you.聽 Today, for the first time, I used the cruise control. So perhaps that is a contributing factor? There was however today about 10 minutes of the driving was in slow moving traffic. Must say I really like the experience (a steadier and smoother drive) and also noticed that as much as the mpg indicator did fluctuate, it was at higher mpg and also often showing 99.9. Moving forward, will be using the cruise control often. Quote Link to comment Share on other sites More sharing options...
unofix Posted March 30 Share Posted March 30 1 hour ago, Niru said: as the mpg indicator did fluctuate, it was at higher mpg and also often showing 99.9. Not many people bother with the Instantaneous mpg, most just select the average mpg display. 1 Quote Link to comment Share on other sites More sharing options...
