fsmith Posted October 21, 2010 Share Posted October 21, 2010 hi im new to this forum but i think this is the right place to post this i have a problem with my windows. They work on and off. The car as always done it since i had it but its starting to bother me alot now. Quote Link to comment Share on other sites More sharing options...
ilanbutler Posted October 21, 2010 Share Posted October 21, 2010 Hi i have had a similar problem mine was down to a controller unit behind the fuse box located at the back of the glove box. But the quickest way to get to it is to remove the carpet underneath the glovebox and stick your hand up there. It sticks out from it and is clipped in on mine it was lose though so i just pushed it in otherwise get a new one or second hand from the scrapper. Failing this its probably the relay/fuse or window motor but its unlikley to be the motor if its more than one window. Good Luck ilanbutler 1 Quote Link to comment Share on other sites More sharing options...
fsmith Posted October 21, 2010 Author Share Posted October 21, 2010 thanks for a quick answer i will try it later on .. Quote Link to comment Share on other sites More sharing options...
fsmith Posted October 28, 2010 Author Share Posted October 28, 2010 Hi i looked at what you said i found a black rectangular object on the back of the fuse box i took it out blew the dust from it and put it back in and hey presto it works perfectly, thanks ilanbutler 1 Quote Link to comment Share on other sites More sharing options...
gennibean Posted September 12, 2014 Share Posted September 12, 2014 Hi, I'm new to with a 1994 Fiesta mk 3. Have tried what was said but my passenger side front electric window motor still won't work. Any ideas you guys? Thanks Gennibean. Quote Link to comment Share on other sites More sharing options...
artscot79 Posted September 12, 2014 Share Posted September 12, 2014 By the age of the car ide say the motor has likely gone the fiesta was prone to water getting into the motor the runners corroding and wires breaking also check the fuses Quote Link to comment Share on other sites More sharing options...
