footfistart Posted December 24, 2012 Share Posted December 24, 2012 Hello all first off happy Christmas to all. I have a question. Will the rs headlights fit to my focus. Mine is a zetec tdci. I'm wanting to put hids on put I wanted some headlights with projectors. And also will the motors still work for the levelling? Or it is a matter of a direct swap? Many thanks Ryan Quote Link to comment Share on other sites More sharing options...
TDCiST Posted December 24, 2012 Share Posted December 24, 2012 legally, for HID's you need auto levelling and i believe headlight wash also... Quote Link to comment Share on other sites More sharing options...
footfistart Posted December 24, 2012 Author Share Posted December 24, 2012 Right ok then but how does everyone else get away with it. Surely having the projectors will concentrate the beam much better than a standard headlight. So is it a straight swap for the headlights or am I needing to do anything. And with the levelling motors work? Quote Link to comment Share on other sites More sharing options...
Preee Posted December 25, 2012 Share Posted December 25, 2012 You would need the leveling sensors. Unless you pre set them. They would also fail an mot without the washers and auto self level Quote Link to comment Share on other sites More sharing options...
Haz93 Posted December 26, 2012 Share Posted December 26, 2012 All the parts for the washer system come to about £300 from ford. The levelling sensors can be sourced from breakers and eBay. The headlights them selves are a direct swap if you have the 10pin headlight loom. They won't work if you only have the 7 pin loom. I have found them to be much more effective than the halogen ones, and can be manually adjusted using an Allen key until the sensors are fitted. As a test I fitted one halogen and one bi xenon unit to see the difference and you would be amazed how different the beam pattern is. They are much more focused and have a crisp cut off line. As they project the light forwards instead of reflecting it, the actuall beam is a lot lower and less dazzling. Quote Link to comment Share on other sites More sharing options...
DJ_Andy_M Posted December 26, 2012 Share Posted December 26, 2012 Is this the addtional wiring you require for fitting the RS/ST headlights? I had thought about getting a set my self. Quote Link to comment Share on other sites More sharing options...
