becky boy Posted January 20, 2013 Share Posted January 20, 2013 my key fob has stopped working and when I open my door with the key the alarm goes off can anyone help please Quote Link to comment Share on other sites More sharing options...
refdt Posted January 20, 2013 Share Posted January 20, 2013 Stupid question but have you tried replacing the battery. Quote Link to comment Share on other sites More sharing options...
becky boy Posted January 20, 2013 Author Share Posted January 20, 2013 yes its not that it just stopped working the other day Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted January 20, 2013 Share Posted January 20, 2013 I suggest retraining your car to the remote... Insert the ignition key and turn from position II (Ignition) to position 0 (All off) and back four times within three seconds. Remove the ignition key. The locking control system is now in "learn mode" for the next 20 seconds and the red warning system LED (By the clock) stays on continuously to indicate this. During the 20 seconds press one of the transmitter buttons. The remotes signal and code number is learned by the locking module and is indicated by flashing the warning system LED. Wait until learn mode times out (20 seconds) or switch the ignition back to ON. Quote Link to comment Share on other sites More sharing options...
becky boy Posted January 20, 2013 Author Share Posted January 20, 2013 I have just tried that but it wont work the red light won"t stay on it just flashes Quote Link to comment Share on other sites More sharing options...
becky boy Posted January 20, 2013 Author Share Posted January 20, 2013 I can only see one red light between the temp and petrol gauge and it just flashes Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted January 21, 2013 Share Posted January 21, 2013 Thats the immobiliser, that light should also flash. If its not happening, you may not be turning the key quick enough...? I struggled when I last tried this to be honest... Quote Link to comment Share on other sites More sharing options...
becky boy Posted January 21, 2013 Author Share Posted January 21, 2013 there is no other light that will come on I have tried again since you said Quote Link to comment Share on other sites More sharing options...
Andy H Dibley Posted January 21, 2013 Share Posted January 21, 2013 That way of retraining the car won't work on a 2008 Focus, I don't believe. That was the old style way of adding keys, now I believe you have to take them back to Ford to have them reprogrammed on to the car's GEM module. See its difficult to tell if the key is doing anything really. Can you 100% confirm the battery is a ok and that it is making contact with the terminals, its not installed the wrong way round etc. Have you dropped the key recently? Quote Link to comment Share on other sites More sharing options...
refdt Posted January 26, 2013 Share Posted January 26, 2013 There is a key cutting company called thompsons that do them. Just for a normal 3 button key not the flip as he didnt do them was going to cost me £95 all programmed in. Not sure how much ford would charge for that. Quote Link to comment Share on other sites More sharing options...
MrRedman Posted January 26, 2013 Share Posted January 26, 2013 i had a problem with my fob in the end after much messing about i soaked the circuit board in wd40 next day working a treat! Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted January 27, 2013 Share Posted January 27, 2013 Ford quoted me £145 for a standard remote key or £165 for a flip key, got an auto locksmith out next day, £130 all in for a flip key... Quote Link to comment Share on other sites More sharing options...
