Bonnet Won't Open Anymore In 1.6 Tdci
Hi guys I need your help figuring out how to open my bonnet it's been fine all along and all of a sudden I try to open it there's nothing happening...the key turns ok but there's no click I've tried to turn it either way still no luck please help me out .
Nash this topic has been covered many times on here briggante recently did a guide on how to do it basically what your looking for is through the grill you will see a rubber grommet on the latch using a long screwdriver remove that comes out easy there's a white disc behind that this needs pushing back to relocate it now briggante. Did say it should be turned into a certain position so it goes straight back in .if you trawl back through the posts on here I'm sure you will find the guide sure it was only last week.
Thankx guys for your responses I've found yhe guide and will try it later.
