M4RC Posted August 26, 2014 Share Posted August 26, 2014 I've been looking at these... Basicaly I'm just wondering how these work, are they worth it? What will it achieve? I'd be fitting this to a fiesta mk6 ST Quote Link to comment Share on other sites More sharing options...
DieselPig Posted August 26, 2014 Share Posted August 26, 2014 Rev limiter works by causing a misfire to limit the engine RPM, launch control sets a pre-set rev limit until the car reaches a certain speed. Achieves little on the High Street apart from the attention of the Police, but its your money. Quote Link to comment Share on other sites More sharing options...
Gary.J Posted August 26, 2014 Share Posted August 26, 2014 Why not look at the Omex webiste. That tells you exactly what it does. Rev Limiter Protect your engine At a user definable engine speed, a selectable soft or hard ignition cut rev limitreduces engine power safely to limit the engine speed, protecting your engine fromdamage caused by over-revving A side effect of this is the unburnt fuel causes a misfire when the ignition lights it up. Sounds good to some, but can, and most likely will destroy the exhaust over time. Also ruins a cat as unburnt fuel contaminates the matrix. Launch control Consistent faster starts A launch control limit is user definable and operated with the supplied launch buttonto give consistent starts, reducing the chance of wheelspin or engine 'bog down'.With turbocharged engines this allows you to build boost at low engine speeds forthe launch. Quote Link to comment Share on other sites More sharing options...
M4RC Posted August 27, 2014 Author Share Posted August 27, 2014 Seems decent but pretty pointless for me I guess Quote Link to comment Share on other sites More sharing options...
