billyfullbrook Posted August 31, 2014 Share Posted August 31, 2014 I've got a st-2 2013 and thinking about getting a bluefin, but will it invalidate the warranty? Can it be traced etc Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
MarksST Posted August 31, 2014 Share Posted August 31, 2014 It will if they can check when the ecu was flashed, The bluefin hasn't got many good reviews from people who have used it on STs, I can't remember the last time someone went down that route either. Have a look at revo, Mountune, Finsport, first. Quote Link to comment Share on other sites More sharing options...
billyfullbrook Posted August 31, 2014 Author Share Posted August 31, 2014 I just don't want to void warranty just in case! Mp215 is a bit pricey and a few people have said it doesn't push 215bph more like 205bph Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Clarky2013 Posted August 31, 2014 Share Posted August 31, 2014 I've heard nothing but bad things about the bluefin for the st, avoid like the plague. There is an owner who has even had to sell his st as the bluefin has screwed up the ecu. Quote Link to comment Share on other sites More sharing options...
billyfullbrook Posted August 31, 2014 Author Share Posted August 31, 2014 What's the best way to go? Without voiding warranty? Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
iNath Posted August 31, 2014 Share Posted August 31, 2014 What's the best way to go? Without voiding warranty? Sent from my iPhone using Ford OC Mountune is the only way to go without voiding the warranty. Quote Link to comment Share on other sites More sharing options...
Clarky2013 Posted August 31, 2014 Share Posted August 31, 2014 Keep it standard as it's great that way, or mp215 kit. To be blunt there is no way to get more than 212- 213 bhp (mp215 is ps ) without voiding the warranty, currently. You can look at finsport stage 1 who can supply a flash lead to put the ecu back to stock map if there are issues but that opens a can of worms as some people claim a tech can still see the map on the ecu has been changed at some point therefore voiding warranty if something goes wrong. Quote Link to comment Share on other sites More sharing options...
billyfullbrook Posted August 31, 2014 Author Share Posted August 31, 2014 Mountune is the only way to go without voiding the warranty. Have you got mountune on your st? Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
iNath Posted August 31, 2014 Share Posted August 31, 2014 Have you got mountune on your st? Sent from my iPhone using Ford OC I don't even have my ST at the moment let alone Mountune :( Been in the dealer for 5 weeks now. Quote Link to comment Share on other sites More sharing options...
MarksST Posted August 31, 2014 Share Posted August 31, 2014 I had it on my last ST and was really pleased with it, it made 217 on Jamsports rollers. Getting it fitted again to my new ST on Friday. Quote Link to comment Share on other sites More sharing options...
Clarky2013 Posted August 31, 2014 Share Posted August 31, 2014 What's up with yours nath? Swear you haven't had It long anyway :( Quote Link to comment Share on other sites More sharing options...
MarksST Posted August 31, 2014 Share Posted August 31, 2014 I don't even have my ST at the moment let alone Mountune :( Been in the dealer for 5 weeks now. Was it you that had an oil leak? That is quite a wait. Quote Link to comment Share on other sites More sharing options...
billyfullbrook Posted August 31, 2014 Author Share Posted August 31, 2014 I had it on my last ST and was really pleased with it, it made 217 on Jamsports rollers. Getting it fitted again to my new ST on Friday. Looks like that could be the way ahead! Any other good mods to take into consideration? Any will be appreciated! Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
iNath Posted August 31, 2014 Share Posted August 31, 2014 What's up with yours nath? Swear you haven't had It long anyway :( Was it you that had an oil leak? That is quite a wait. Sorry to go off topic. I've had it since May and it's never quite been right, misfiring and loosing power (even going in to limp mode) They've replaced crankshaft sensor, crankshaft pulley and most recently got auth to replace the PCM (ECU!!) which is now on back order :( Luckily (if lucky at all) the courtesy car is top of the range 1.0l 125PS Titanium X which I've had for 5 weeks now! Quote Link to comment Share on other sites More sharing options...
billyfullbrook Posted August 31, 2014 Author Share Posted August 31, 2014 Sorry to go off topic. I've had it since May and it's never quite been right, misfiring and loosing power (even going in to limp mode) They've replaced crankshaft sensor, crankshaft pulley and most recently got auth to replace the PCM (ECU!!) which is now on back order :( Luckily (if lucky at all) the courtesy car is top of the range 1.0l 125PS Titanium X which I've had for 5 weeks now! At least you haven't got a 1.25 zetec as a courtesy car i suppose... Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
MarksST Posted August 31, 2014 Share Posted August 31, 2014 Looks like that could be the way ahead! Any other good mods to take into consideration? Any will be appreciated! Sent from my iPhone using Ford OC There's not many extra parts that will keep warranty, Mountune intercooler and soon to be release ( hopefully) cat back exhaust will. Intake hose is worth a look and takes a couple of mins to swap if you have a problem. Quote Link to comment Share on other sites More sharing options...
Clarky2013 Posted August 31, 2014 Share Posted August 31, 2014 + boost pipes for improved pickup Quote Link to comment Share on other sites More sharing options...
billyfullbrook Posted August 31, 2014 Author Share Posted August 31, 2014 Okay, cheers guys, much appreciated! Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
