troy45 Posted December 11, 2014 Share Posted December 11, 2014 Swapped to my standard ST wheels for winter last weekend - saves my Oz's getting cruddy from all the salt and grime plus standard wheels lot easier to clean, or can be left grubby if needed. Noticed this when I did the opposite swap earlier this year, all 4 tyres have a ridge of tread in the centre of the tyre which is about 1mm proud of the rest of the tread. Got same tyres on the 18's but tread on those is fine. The tyres above drove fine and didn't give me any problems, alignment was checked last year after the clutch and diff were done with and tread ware is fairly even. Rotating the tyres when I ran them this year doesn't seem to have made it worse or better. Plus got decent mileage out of the set and still have 3-5mm tread left. Going to change the set anyhow before I refit the wheels. Quote Link to comment Share on other sites More sharing options...
addison94 Posted December 13, 2014 Share Posted December 13, 2014 What pressures you set it to normally? I'm in the tyre trade, bit of a weird wearing indeed! Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
troy45 Posted December 13, 2014 Author Share Posted December 13, 2014 Running 34psi front & rear, checked weekly. Would wonder if there's a problem with the rubber compound not being regular across the tyre. Could check DOT codes to see if the tyres are all the same age or not but they're buried in the spare room now. Quote Link to comment Share on other sites More sharing options...
addison94 Posted December 14, 2014 Share Posted December 14, 2014 Could well be the compound, I'd send the photos to main dealer they might offer you a better answer! Sent from my iPhone using Ford OC 1 Quote Link to comment Share on other sites More sharing options...
Grandad bert Posted February 3, 2015 Share Posted February 3, 2015 Hello trot, I used to work as a tyre fitter, many top brand tyres have duel compound, centre being harder for mileage/ motorway and the shoulders slightly softer for cornering grip, continentals tend to do a similar thing, take care Sent from my iPhone using Ford OC 1 Quote Link to comment Share on other sites More sharing options...
Grandad bert Posted February 3, 2015 Share Posted February 3, 2015 Sorry, ment troy not trot, poxy auto correct Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
troy45 Posted February 3, 2015 Author Share Posted February 3, 2015 Hello trot, I used to work as a tyre fitter, many top brand tyres have duel compound, centre being harder for mileage/ motorway and the shoulders slightly softer for cornering grip, continentals tend to do a similar thing, take care Sent from my iPhone using Ford OC Was aware of dual compounds being used for bike tyres but never considered it for car tyres as they always have full tread in contact with the road - that could explain things. Not seeing the same wear (yet) on my set of 18's but they've not worn as low as the 19's. Will see how they compare depending how much more mileage they get before I'm swapping wheels about again. Seen good reviews on the Conti SP5's but may just stick with the Goodyears as I can't fault them even with the strange wear lines. Quote Link to comment Share on other sites More sharing options...
FoveaCentralis Posted April 10, 2015 Share Posted April 10, 2015 I was searching this same issue and came across your thread. I've had exactly the same thing happen on my rear tyres with a raised ridge in the centre being approx 1mm proud of the surrounding tread. There has recently started a slight drone or possibly wheel balance issue at the back end, but as yet I don't know if this is the general tyre wear & tear, or maybe from pothole damage. Both the rears are still a few mm above the minimum tread indicator bars, and this is after 35,000 miles so I can't grumble about these tyres at all as they've been great. I'm in the tyre fitters on Tuesday to investigate and see if it's just a re-balance/tracking issue, or if the tyres are now just past it. After the tyre fitter visit I'll update this post for info purposes and anyone else searching for this same issue. Left & Right pics attached. Incidentally, I did have the same tyres on the front, but just changed them when they hit the minimum depth. I don't recall any issues at all with them up to the point of renewing them, but unfortunately I just can't remember if the front tyres had the raised lines on them in the centre as shown in the images referred to in this thread. Regards to all. Quote Link to comment Share on other sites More sharing options...
troy45 Posted April 23, 2015 Author Share Posted April 23, 2015 Interesting to see it's not just the set I had which showed this - I did mention it to the tyre fitter when the new set was being fitted and he did have a term for what it was but I can't remember what it was. Same for me though it's mainly been an appearance query, can't fault how the tyres performed while I used them. Quote Link to comment Share on other sites More sharing options...
FoveaCentralis Posted April 26, 2015 Share Posted April 26, 2015 Closer inspection of the rear tyres shows flat spots on the inside edge of both rear tyres. It was worse on the rear left which would account for the droning & balance issue previously described. Possible pothole damage may have contributed to this, or maybe its just construction of the tyres themselves. Anyway, both my rear tyres took 35,000 miles to get to this stage so I can't grumble too much I suppose. I mentioned to the tyre fitter that I'd heard the Eagles were known for this uneven wear pattern previously - and his reply was 'They still are!'. I just replaced the rears with Avons and all is good again now. Quote Link to comment Share on other sites More sharing options...
