Josh775 Posted December 14, 2014 Share Posted December 14, 2014 Hi all, It was really frozen the other day and I left my wipers on the Stork so when I turned my over they tried moving some ice.... Turned them off subsequently and now even a day after my front and rear wipers won't work and neither will my jet sprays.... When I click the stork up no matter what position nothing happens. Would this just be a relay? Or is something burnt out? Any tips? Cheers, Josh. Quote Link to comment Share on other sites More sharing options...
artscot79 Posted December 14, 2014 Share Posted December 14, 2014 Check the fuses under the glove box Quote Link to comment Share on other sites More sharing options...
Josh775 Posted December 14, 2014 Author Share Posted December 14, 2014 Ok thanks will check in morning. Is this what I need if it's gone? http://www.ebay.co.uk/itm/Ford-Focus-mk1-98-05-wiper-relay-5-pin-PA66-GF25-/121473584131?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c4863cc03 or is there something else also? Thanks Quote Link to comment Share on other sites More sharing options...
Josh775 Posted December 14, 2014 Author Share Posted December 14, 2014 Ok; Will start with fuses in the morning.... see if they're OK. Then if they are will look at relay. Just doesn't make any sense! Quote Link to comment Share on other sites More sharing options...
troy45 Posted December 14, 2014 Share Posted December 14, 2014 It's that type of situation where fuses earn their keep - if the wiper motor is overloaded from trying to move ice but failing, while there is still power to it you're risking burning out the motor or in worst case setting fire to the wiring from pulling too much current through it. So they engineer in a replaceable weak point (the fuse) which fails at a more or less known value before any permanent damage is done. Quote Link to comment Share on other sites More sharing options...
kev62 Posted December 14, 2014 Share Posted December 14, 2014 Same thing happened to me about 2 years ago and it had me beat trying to figure out what was wrong. I ended up putting it into my local dealer to sort it out turned out to be something in the gem module which cost me in excess of £500 to sort don't know why the fuse hadn't went first lol . Fingers crossed for u tho. Quote Link to comment Share on other sites More sharing options...
stef123 Posted December 14, 2014 Share Posted December 14, 2014 It's that type of situation where fuses earn their keep - if the wiper motor is overloaded from trying to move ice but failing, while there is still power to it you're risking burning out the motor or in worst case setting fire to the wiring from pulling too much current through it. So they engineer in a replaceable weak point (the fuse) which fails at a more or less known value before any permanent damage is done. Contrary to popular believe, you will be suprised at how much 'extra' load you can put on fuses without them blowing. Quote Link to comment Share on other sites More sharing options...
mjt Posted December 15, 2014 Share Posted December 15, 2014 Quite. The rating of a fuse is not the current it will blow at but the maximum current it can carry indefinitely without blowing. Quote Link to comment Share on other sites More sharing options...
troy45 Posted December 15, 2014 Share Posted December 15, 2014 So they engineer in a replaceable weak point (the fuse) which fails at a more or less known value before any permanent damage is done. Thought I'd covered myself there with the 'more or less' bit ;) 1 Quote Link to comment Share on other sites More sharing options...
stef123 Posted December 15, 2014 Share Posted December 15, 2014 Thought I'd covered myself there with the 'more or less' bit ;) To the average guy off the street, the rating on the fuse is close enough A circuit requiring 35 amps will be fused at 40 with a cable suitable of carrying atleast 40 amps, Although in reality that fuse may be able to draw 60 amps for say, 20 mins before it actually blows (just depends on fuse type and rating). A large surge in current or short circuit and that fuse will blow very quickly - which is really all that matters. 2 Quote Link to comment Share on other sites More sharing options...
Irishman1127 Posted December 16, 2014 Share Posted December 16, 2014 What about people who use a 30A fuse in a 10A circuit? That always makes me laugh... Quote Link to comment Share on other sites More sharing options...
stef123 Posted December 16, 2014 Share Posted December 16, 2014 What about people who use a 30A fuse in a 10A circuit? That always makes me laugh... Ahh the 30 amp will be fine for now.. Quote Link to comment Share on other sites More sharing options...
Irishman1127 Posted December 16, 2014 Share Posted December 16, 2014 I remember years ago when cars had glass type fuses, either they were wrapped in foil or you'd find a gutter bolt with the head cut off it.... Lol 1 Quote Link to comment Share on other sites More sharing options...
stef123 Posted December 16, 2014 Share Posted December 16, 2014 I still come across 'homemade' fuses often enough. Haha, the good old roofing bolt? People must realise that when a fuse blows it's for good reason not just a nuisance. Explain to your house/car insurance when it goes on fire.. Quote Link to comment Share on other sites More sharing options...
