SeanW Posted January 2, 2015 Share Posted January 2, 2015 Could somebody with Microcat do me a favour? I'm trying to find out if there's a part number for a sealing strip. The part in question is around the top of the front fog light housing. It's about 50cm long (give or take) and about a 5mm square cross section. I've found a potential replacement on eBay, but the seller reckons it's only 30cm long. And the part numbers on the label aren't yielding any results Quote Link to comment Share on other sites More sharing options...
Dee_82 Posted January 2, 2015 Share Posted January 2, 2015 I just checked and its not listed as far as I can see one thing tho, the fog light housing is only about 30 cms across the top.. Quote Link to comment Share on other sites More sharing options...
SeanW Posted January 2, 2015 Author Share Posted January 2, 2015 Thought as much!! The strip extends down each side and stops just on the bottom - a little shy of 50cm in length. Might just order 4 of the strips and use 2 per side - only a slight trim lol Quote Link to comment Share on other sites More sharing options...
