Sagee Posted March 5, 2015 Share Posted March 5, 2015 I have a rattle in the back of my fiesta, can't seem to stop it rattling! Anyone got any ideas? Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Paramanic Posted March 5, 2015 Share Posted March 5, 2015 Seat belts on the plastic? Or in boot Quote Link to comment Share on other sites More sharing options...
Jakeeyy_fiesta Posted March 5, 2015 Share Posted March 5, 2015 Inside car or outside? Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Sagee Posted March 5, 2015 Author Share Posted March 5, 2015 I can hear it on the inside but I can't be sure if it's coming from the outside or inside? Quote Link to comment Share on other sites More sharing options...
Jakeeyy_fiesta Posted March 5, 2015 Share Posted March 5, 2015 Is it when your driving or stand still? Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Sagee Posted March 5, 2015 Author Share Posted March 5, 2015 When I go over rough road or big bumps Quote Link to comment Share on other sites More sharing options...
Jakeeyy_fiesta Posted March 6, 2015 Share Posted March 6, 2015 Have a look at the back where you exhaust sits and check above that the heat plate hasn't dropped. Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Sagee Posted March 6, 2015 Author Share Posted March 6, 2015 I had to put a standard exhaust on as the St one got a hole in it! Would it be that? Quote Link to comment Share on other sites More sharing options...
BobbyDee Posted March 6, 2015 Share Posted March 6, 2015 Might sound daft but is your spare wheel in properly? 1 Quote Link to comment Share on other sites More sharing options...
Sagee Posted March 6, 2015 Author Share Posted March 6, 2015 Ye I thought that too but I took it out to see, but still got the noise! Quote Link to comment Share on other sites More sharing options...
Jakeeyy_fiesta Posted March 6, 2015 Share Posted March 6, 2015 I can't see you changing the exhaust would be an issue, did you check your heat tray hasn't dropped? Sent from my iPad using Ford OC 1 Quote Link to comment Share on other sites More sharing options...
Sagee Posted March 6, 2015 Author Share Posted March 6, 2015 How would I check that? Quote Link to comment Share on other sites More sharing options...
Paramanic Posted March 6, 2015 Share Posted March 6, 2015 Look under car and above the exhaust is a foil is it resting on the exhaust or is it still attached to large washers with bolts 1 Quote Link to comment Share on other sites More sharing options...
Jakeeyy_fiesta Posted March 6, 2015 Share Posted March 6, 2015 Yeah what he said lol Sent from my iPad using Ford OC Quote Link to comment Share on other sites More sharing options...
Sagee Posted March 6, 2015 Author Share Posted March 6, 2015 if it was knocking how would fit the exhaust problem? Quote Link to comment Share on other sites More sharing options...
Paramanic Posted March 6, 2015 Share Posted March 6, 2015 Usually some of them rust or come away from the existing bolt what you do is get a bigger washer and pin it back up or if a remember what a did was a got 2 2p coins put it under the large washer already there from before and wedged them in and tightened it so it wouldn't move lol a common thing in mk6 1 Quote Link to comment Share on other sites More sharing options...
Sagee Posted March 6, 2015 Author Share Posted March 6, 2015 Okay I will try it!! Might come back to you if I can't solve the problem haha Quote Link to comment Share on other sites More sharing options...
