Lenny Posted March 15, 2015 Share Posted March 15, 2015 Focus 1.6TDCi think I'm reaching boost limit which is cutting boost, In 5th put foot to floor and boost hits 25psi then drops to 5psi shoots up to 25psi again then drops back to 7psi slowly building up boost like a choo choo The focus has had the dpf removed, 2.5" back pipe and remapped, Im thinking this problem may be overboost Where the turbo is creating 22psi which is the boost pressure sensor limit, The ecu is then cutting boost which causes the drop, But when reactivated the boost reaches limit again. Perhaps a bigger intercooler may help either to prevent Choo Choo 1 Quote Link to comment Share on other sites More sharing options...
Ianb Posted March 15, 2015 Share Posted March 15, 2015 How strange.. :/ Sent via carrier pigeon using Ford OC Quote Link to comment Share on other sites More sharing options...
iantt Posted March 15, 2015 Share Posted March 15, 2015 has it just started doing it for no reason or since any particular part fitted, do you know what the mapped boost limits are set to at all engine rpm bands does it do it at a particular road speed./engine rpm speed was the remap designed for less back pressure from exhaust mods? 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted August 16, 2015 Author Share Posted August 16, 2015 How strange.. :/ Sent via carrier pigeon using Ford OC has it just started doing it for no reason or since any particular part fitted, do you know what the mapped boost limits are set to at all engine rpm bands does it do it at a particular road speed./engine rpm speed was the remap designed for less back pressure from exhaust mods? This problem has been resolved since fitting the K&N57s induction kit The boost doesnt drop off on full throttle in 4th and 5th :) 2 Quote Link to comment Share on other sites More sharing options...
