gaz82 Posted February 26, 2016 Share Posted February 26, 2016 hey i wonder if anyone has had the same problem as me i've got a 2010 2.0l focus titanium 4 door all of a sudden these faults as appeared all at once both rear doors won't remotely lock have to press in the lock on rear door to lock the car now both rear windows don't function at all via door control or drivers control panel all interior lights are not working ford/sony head unit completely dead have check all fuses in main and passenger fuse box's and didn't find any blown I have tried to trace what electrical diagrams i have for the car and all seams to point to the GEM, Are there any replaceable relays or fuses other than the locations i've stated as it would seam on wiring diagrams there are more relays within the car somewhere but i've yet to find them or the GEM any help would greatly be received thanks in advance Quote Link to comment Share on other sites More sharing options...
BOF Posted February 26, 2016 Share Posted February 26, 2016 Check the battery voltage! There is a possibility that you have a dead cell (or two) in your battery. Also,there is a possibility that the voltage goes down a long way when you start the engine, and they could be re-setting then (does or did any of the door locks 'clatter' when you are starting the car?). That said, there is a possibility that just disconnecting the battery and re-connecting might do the trick - a bit of a long shot, but it is cheap. And, if it is a low battery voltage, it might not last for long. And, given that the HU is already dead, I probably don't need to warn you about needing the radio code, because you already need that... 2 Quote Link to comment Share on other sites More sharing options...
gaz82 Posted February 26, 2016 Author Share Posted February 26, 2016 i have disconnected the battery and re-connected it and this made no difference it tests at 12v from the incar dash test trick all the faults are permanent there is no lights no, HU, no power windows to the rear and no Power locking to the rear the front windows work fine and do the doors lock and thanks for the warning i did make sure i had the radio key handy Quote Link to comment Share on other sites More sharing options...
artscot79 Posted February 26, 2016 Share Posted February 26, 2016 12v a bit low you should at minimum get 12.5 a free battery test will sort that have you pulled the fuse board down in the pass footwell and made sure all the plugs are in tight they can be kicked loose 2 Quote Link to comment Share on other sites More sharing options...
gaz82 Posted February 26, 2016 Author Share Posted February 26, 2016 I will double check the voltage with me meter tomorrow I have pulled the fuse board down and checked all the fuses but i didn't notice any wiring harness's lose but i will disconnect and reconnect them and see what that does an auto-electrician friend seam to think the mk2 leaks within the passenger footwell onto the passenger fusebox and corrodes the terminals so it will be a good idea to take the leads apart and look for water but the floor is never damp ( i thought this was early focus mk1 problem though the windscreen seal for the pollen filter, mk2 pollen being inside not to have this problem ?) will update tomorrow thanks for the advise so far Quote Link to comment Share on other sites More sharing options...
mockneyferguson Posted February 26, 2016 Share Posted February 26, 2016 Check the plugs are in the bottom of the fuse box correctly and the clips are locked in 2 Quote Link to comment Share on other sites More sharing options...
artscot79 Posted February 26, 2016 Share Posted February 26, 2016 its a mk1 problem not mk2 so yes he's mistaken on the leak issue 2 Quote Link to comment Share on other sites More sharing options...
gaz82 Posted February 27, 2016 Author Share Posted February 27, 2016 Update voltage across battery 12.41 disconnected passenger fuse box/gem all looks clean no sign of water damage or rusty dirty connections looks like new connected back together still no go looks like could be a fault in the gem on the wiring schematics there is a section of wiring that links to all the faults Iam receiving Looks like ford decided to go with smd/smt soldered relays now so not as easy to test the relays and concerned trying to open the gem may make more go faulty I am confident to solder components but which if any relay is the faulty one won't be easy to find out plus this could be a can-bus issue within the gem I guess ? I would guess it's off to ford for diagnostic I can feel the wallet emptying already 😁 Has anyone on here had these passenger fuse boxes open and took Piccys ? And if so what where you trying to fix ? Quote Link to comment Share on other sites More sharing options...
Scotchx Posted January 5, 2017 Share Posted January 5, 2017 Hello I have the same problem with my Ford Focus MK2.5 Radio does not turn on Internal light does not turn on Rear doors do not lock Rear windows do not work What was the solution to this problem? Quote Link to comment Share on other sites More sharing options...
