Help with indicator lights
Hello, could anyone advise me?? My street ka indicator lights won't turn off unless the battery is disconnected !! Has anyone had this problem ? And any ideas what to do Thankyou
Faulty relay or ground issue - either way you are going to have to get out the multimeter or leccie probe!
Easiest thing to check first would be the indicator switch/stalk.
Do you meaN when you disconnect the battery the indicators are off when its plugged back in?
If it does then it will be the relay/ground and if they come back on when the battery is plugged back in i would test the indicator switch first!
alarm
