simone Posted April 9, 2016 Share Posted April 9, 2016 Hey all, As the title says I want to locate the place where I can check and fill transmission oil if it is needed, can anyone tell where it is located on MK1 1.6 petrol. Thanks in advance Quote Link to comment Share on other sites More sharing options...
artscot79 Posted April 10, 2016 Share Posted April 10, 2016 gearbox check plug is the only way to check unless you mean the clutch fluid which shares the resevoir with the brake fluid Quote Link to comment Share on other sites More sharing options...
simone Posted April 11, 2016 Author Share Posted April 11, 2016 No its the gearbox oil I need to check, do you know where that plug is located? Quote Link to comment Share on other sites More sharing options...
