mitch84 Posted October 22, 2009 Share Posted October 22, 2009 hi i noticed yesterday that when i sprayed the window washers the spray mostly missed my front windscreen ,they seemed fine the last time i done it but now they completly miss. i did read a topic about the same thing is this a common problem that can be fixed easy ? thanks Quote Link to comment Share on other sites More sharing options...
irononreverse Posted October 22, 2009 Share Posted October 22, 2009 hii noticed yesterday that when i sprayed the window washers the spray mostly missed my front windscreen ,they seemed fine the last time i done it but now they completly miss. i did read a topic about the same thing is this a common problem that can be fixed easy ? thanks You can insert a pin into the nozzle and change where it points. My far left nozzle was missing the area covered by the wipers so I just adjusted it. Simple. Quote Link to comment Share on other sites More sharing options...
xxtrickzxx Posted October 22, 2009 Share Posted October 22, 2009 You can insert a pin into the nozzle and change where it points. My far left nozzle was missing the area covered by the wipers so I just adjusted it. Simple. ive adjusted my drivers side one twice now as the jet seems to keep moving up, proberly potholes causing it,i made a thread about it a couple of months ago and know one replied so i dont think its a common fault Quote Link to comment Share on other sites More sharing options...
mitch84 Posted October 23, 2009 Author Share Posted October 23, 2009 ive adjusted my drivers side one twice now as the jet seems to keep moving up, proberly potholes causing it,i made a thread about it a couple of months ago and know one replied so i dont think its a common fault cheers guys , my dad sugested the pin thing and that fixed it. :) Quote Link to comment Share on other sites More sharing options...
