Amos Posted June 6, 2016 Share Posted June 6, 2016 Hi people I have just recently baught a 2015 st2 focus and wandering what HID/ Xeon light kits are available for the car? Any help would be appreciated cheers Quote Link to comment Share on other sites More sharing options...
alexp999 Posted June 6, 2016 Share Posted June 6, 2016 Any high brightness halogen should be okay like osram night breakers etc. You can't use HID replacements as the Focus has reflector headlight clusters. Otherwise you'd need to replace the whole headlights. Just remember the more blue you go, the less usable light there is. About 4500-5000k is the limit iirc. Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted June 7, 2016 Share Posted June 7, 2016 You could change the complete hadlight but the amount of work to get them to work correctly like Factory is a lot. 1. You need the complete headlights 2. Requires both headlight leveling sensors & module. 3. Washer Jets for the Headlights. I would just get the Osram. easier & cheaper. Alex is right about the light output. Max for me is 6000K but does depend on the system some are stronger then others. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted June 8, 2016 Share Posted June 8, 2016 Zenon headlights on the ST need programming in too. Quote Link to comment Share on other sites More sharing options...
