KA 2004 1.3 Duratec. Alternator Charging light on
Hello
The charging warning light has been on for many months.  Battery still charges and car starts first time, every time, so I assumed it was the 'broken wire in alternator connector' issue that a few posts have mentioned on here.
Bought a replacement connector (new connector with 3 wires already connected) and did a perfect job of cutting off the old connector and soldering on the wires of the new connector.  Each wire protected with new heat shrink insulation as well as being taped.
Result:- light still on.
I examined new connector and wires and every thing looks perfect.  I must admit I was surprised not to see any lose connections in the old switch I cut off ... I just assumed it had broken internally.
Anyone have any idea what the problem is?
Alternator still charging fine ... just that annoying light on.  I assume if the alternator ever does stop charging I won't know about it (as light always on) ... that is until battery starts to go flat!!
Any suggestions appreciated.
Sounds like the fault is either in the alternator (could just be bad solder joint on the connector, or something more complex), or just possibly in the PCM or even the instrument cluster (IC).
The monitoring wire from that plug goes to the PCM (engine computer) on my car, and PCM then informs the IC over the CAN bus.
As all this is a bit complex, and may be expensive & hard to fix, if the car works ok, just get a cigar lighter (power outlet) plug in voltmeter. Pretty cheap off Ebay/Amazon. Then you can keep an eye on battery volts, you'll easily see if it is not charging, once you get used to the readings (>14v on charge, <12.5v on discharge)
Peter.
Check the belt tension first.
Check your earth connections as well.
Simple stuff first.
The cigar socket volts tester is always a good idea to have in the car.
http://www.newfrog.com/p/3-in-1-digital-voltmeter-thermometer-12-24v-cigarette-lighter-usb-car-charger-104196.html?utm_source=makesbridge&utm_medium=newsletter&utm_content=memorycards&utm_campaign=20160607&[email protected]&bms.tk=xhDfXr33Kl26Dn17Kr20Jp21Ol30Qk33xnGy&__CBK=3959964e43c25f53d11b997aafc8147c71466477389_1105821
Sounds like a faulty diode in the alternator though!
If the battery light is on without ignition on then the alternator diode is shorted out and you will need a new diode pack.
i had similar so i purchased a replacement alt for £35.00 off the scrappys 4 yrs ago and its been fine since.
http://www.breakeryard.com/car-parts-uk
really good site
It's very likely to be the diode. I replaced with a second hand ebay one and the battery light came on immediately Swapped it for a quintin- hazel new one for£85 and the light went out.
It needs swapping, also if it's overloaded it could smoke or worse catch fire. It might give you a small charge to battery but not enough to convince Cpu that it's correct. Go to Motorland and order a new quintin hazel model. Don't recommend a second hand one.
The advice from Andrew is good, assuming you can do the job yourself. But changing alternators on small, modern cars can be quite difficult. Garage labour costs might double that bill. And there is a small chance the fault could lie elsewhere, in the harness, or connector at the other end.
It would be a good idea to check the temperature of the unit after a decent run. (Carefully!). If hot enough to boil water, it is too hot. But if has worked for months, there does not seem to be a drastic problem, at least not yet.
It is your choice really, depending on finances & your use of the car.
Peter.
If you take the diode pack off its extremely easy to test the diodes if you have a basic multimeter and if you have the soldering knowledge you can buy the diodes off ebay for 5p each and save yourself quite a few quid - 20p or £100? Up to you!
