ZetecShearer1987 Posted July 8, 2016 Share Posted July 8, 2016 Hi Everyone Right, how do i start to try and explain this, As most people are aware on this forum that i have been having issues with my car, in terms of a poor idle, loss of power etc. Its been to my local auto electrician numerous times for diagnostics and checks. They have spend hours and hours trying to find the problem with the car. When they first had the car i made them aware that a new battery was fitted by ford so that shouldnt be the issue. So today the garage gave me a ring saying the battery is not correct for the car even though ford say only this battery is available. The Ford battery is a efb 60amp 590 crank. But when the lads showed me 5 other websites with my car registration inserted the battery that came up everytime was 75amp 730 crank which is more powerful. VARTA... YUASA AND EXIDE direct on there websites state the correct fitment should be that (75amp 730) and not ford's recommended one (60amp 590) Also Halfords and eurocarparts also show the 75amp 730 crank battery. So because they think the battery is to small, that is causing my problems. I rang tc harrisons who stood by the battery size of 60amp 590. any help please Quote Link to comment Share on other sites More sharing options...
JW1982 Posted July 8, 2016 Share Posted July 8, 2016 The Ford dealer is correct. The Ford T6 EFB 60A 590CCA battery is the correct type of battery for the 1.0 and 1.6 ECOboost (and probably also some other engine types). This is the type of battery that is factory fitted to these vehicles. Both my 1.0 ECOboost (125 HP) and my parents 1.6 ECOboost (182 HP) have the Ford T6 EFB 60A 590CCA battery. This type of battery is also specified in the Ford Ecat parts program for these vehicles. On the Focus MK3 the battery capacity is configured in the Central car Configuration. You can fill in your VIN number at the following website (made by the author of the FoCCCus program). http://ford.xtlt.ru/ab/ Configuration parameter #210 shows the type of battery that is specified in the configuration during the production of the car. 2 Quote Link to comment Share on other sites More sharing options...
artscot79 Posted July 8, 2016 Share Posted July 8, 2016 have to agree with the above ford can tell you what was fitted on the production line for that car 2 Quote Link to comment Share on other sites More sharing options...
ZetecShearer1987 Posted July 8, 2016 Author Share Posted July 8, 2016 Just checked on that link it does say my car came with a 60amp 650 cca, my current one is a 60 amp 590 cca can that cause issues as the cold crank is lower Quote Link to comment Share on other sites More sharing options...
iantt Posted July 8, 2016 Share Posted July 8, 2016 i can also confirm the 590cca battery is the correct one , your ford dealer is correct. petrols get 590cca and diesels get 700cca 1 Quote Link to comment Share on other sites More sharing options...
ZetecShearer1987 Posted July 8, 2016 Author Share Posted July 8, 2016 Im at a loss then as thats the only other thing the garage can change to see if it cures the running issues. Theyve checked the car numerous times and the problem seems unfixable Quote Link to comment Share on other sites More sharing options...
artscot79 Posted July 8, 2016 Share Posted July 8, 2016 unless they are able to hook it up like ford the never will get to the bottom of it 2 Quote Link to comment Share on other sites More sharing options...
biff55 Posted July 9, 2016 Share Posted July 9, 2016 i dont see a variation in battery type as the cause of your engine running problems anyway as soon as the car is started the alternator takes over in supplying electrical power and the battery does very little......... sounds like this garage is clutching at straws in their fault diagnosis....... 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted July 9, 2016 Share Posted July 9, 2016 could be your washer pump. now im clutching at straws. 1 Quote Link to comment Share on other sites More sharing options...
