fizzyfizz Posted November 13, 2016 Share Posted November 13, 2016 I've got a problem with my 2009 Fiesta's audio unit and am hoping someone may have some advice. I should point out, this is NOT one of the SYNC units but the system prior to that. I'm finding that when listening to audio from an MP3 player via a cable plugged into the AUX port, the sounds cuts out and the only way to bring it back is to switch the car's audio system off and then back on again. But then the audio cuts off again about 20 seconds later. I've tried different cables and a different MP3 player to eliminate those possibilities. Meanwhile, the radio works fine and doesn't cut off at all. It's just when I have something connected to the AUX port. Also, I don't know if it's connected, but I've noticed recently that the unit 'forgets' my bluetooth paired phone. Any ideas anyone? THANKS Quote Link to comment Share on other sites More sharing options...
Sea view Posted February 6, 2018 Share Posted February 6, 2018 Did you manage to sort this out? Having the same problem Quote Link to comment Share on other sites More sharing options...
fizzyfizz Posted February 6, 2018 Author Share Posted February 6, 2018 Hi Sea View.. YES.. I solved this problem. It's to do with the bluetooth module being faulty and needing replacing (about £80 off eBay) See this thread.. Good luck! Quote Link to comment Share on other sites More sharing options...
