CarEdge Posted January 20, 2017 Share Posted January 20, 2017 Hi, Wondering if my rear defroster is working properly. You can see on the photo that the top part of the rear windscreen remains frosted. There are wires on the windscreen in this area but maybe they are for something else as they are on a different circuit? Could be an antenna? Anyone else noticed this? Quote Link to comment Share on other sites More sharing options...
Kev-Edge Posted January 23, 2017 Share Posted January 23, 2017 Yeah I've noticed this recently, ours is the same, the top couple of lines don't defrost. Quote Link to comment Share on other sites More sharing options...
CarEdge Posted January 24, 2017 Author Share Posted January 24, 2017 It's certainly an antenna. The connectors under the plastic at the back lead to an FM/AM unit. Quote Link to comment Share on other sites More sharing options...
Killer Posted February 1, 2017 Share Posted February 1, 2017 On Tuesday, January 24, 2017 at 4:25 PM, CarEdge said: It's certainly an antenna. The connectors under the plastic at the back lead to an FM/AM unit. I dont get it why fit a sharks fin aerial ( The british version of an antenna) then put onto in the glass as well Quote Link to comment Share on other sites More sharing options...
simonb65 Posted February 1, 2017 Share Posted February 1, 2017 45 minutes ago, Killer said: I dont get it why fit a sharks fin aerial ( The British version of an antenna) then put onto in the glass as well Frequency bands! .. the higher the frequency the shorter the antenna (usually use a 1/4 wave length), so GPS and DAB need a smaller antenna. DAB is region specific (Europe), so it makes sense to make it in a component that can be interchanged depending on the target market. AM/FM are low frequency by comparison and world wide, so the larger length (window element) makes more sense, and is aesthetically more pleasing than a typical 8"-10" long helical stub aerial like on the Kuga, etc.. Saying that, It does seem odd that they opted to use an area which is still in the wiper blade arc and an area that could have done with the heater elements! 1 Quote Link to comment Share on other sites More sharing options...
