Focus MK2 Drivebelt?
14 minutes ago, TomsFocus said:
You'd need a much shorter belt.
Okay mate. Do you know where I can get one? I’ve seen one on eBay which is 975mm (could be original size?) and one which is 802mm (could also be original size or shorter)
You'd have to measure the exact size you'd need I'm afraid.  The non-AC models had a different setup so it's not a simple as just using the belt from those.
Okay, thanks for your help.
Try Cheap Car Parts Online | Car Parts 4 Less UK - Big Brands, Low Prices owned by the same group as Euro Car Parts except Car Parts 4 Less is the mail order branch.
Just type in your car reg. no. and scroll to Car Parts then Engine Parts then under Belts Chains & Tensioners choose Drive Belts.
If you aren't sure give them a call, they have access to several databases on most cars.
Hope this helps.
