pmallinson Posted September 29, 2017 Share Posted September 29, 2017 Hi Guys Not sure if this is a common problem but my estate is getting really wet in the back boot area ? to the point where the back floor mat is soaked and the spare wheel well had about 1/2 inch of water sloshing about in it :-( Any ideas what could be the issue all door seals look ok and there is no obvious signs of where it could be coming in please help if possible Quote Link to comment Share on other sites More sharing options...
Simon_K Posted September 29, 2017 Share Posted September 29, 2017 I’m suffering similarly with mine. So far I’ve added sealant to all of the panel seams where the roof meets the body above the tailgate, and all of the hinge seams too. There’s also a seam under the roof rail cover that can leak. I’ve forced a little sealant in there using a lollipop stick. Also found the wiring harness to the rear light was pinched in the foam seal, possibly letting water in. This has improved my leak, now only have about an egg cup full in the wheel well, not sure if that’s old water leaching out. Hope this helps. Quote Link to comment Share on other sites More sharing options...
pmallinson Posted September 29, 2017 Author Share Posted September 29, 2017 1 hour ago, Simon_K said: I’m suffering similarly with mine. So far I’ve added sealant to all of the panel seams where the roof meets the body above the tailgate, and all of the hinge seams too. There’s also a seam under the roof rail cover that can leak. I’ve forced a little sealant in there using a lollipop stick. Also found the wiring harness to the rear light was pinched in the foam seal, possibly letting water in. This has improved my leak, now only have about an egg cup full in the wheel well, not sure if that’s old water leaching out. Hope this helps. Thanks a lot will look at the points you mention sick of this water ingress ! Quote Link to comment Share on other sites More sharing options...
