WarChild007 Posted October 4, 2017 Share Posted October 4, 2017 Hi, Had the timing belt and waterpump changed on my 2008 1.4 TDCI and now when I move away from stationary I need to put more revs through it or the engine judders and it stalls. I've had the car for about 10yrs so pretty used to it and it seems odd that I have the work done and I get bogged down or stall whilst moving away. Could it be related to the timing belt change? Quote Link to comment Share on other sites More sharing options...
iantt Posted October 4, 2017 Share Posted October 4, 2017 yep if they havent timed it correctly. Quote Link to comment Share on other sites More sharing options...
griffithsbilly86 Posted October 4, 2017 Share Posted October 4, 2017 Take it back and have them redo timing sounds like it's out a tooth. I had the same problem with my old car I timed it up wrong by a tooth and had the same problem as you describe. Luckily I turned it over by hand to make sure nothing was hitting before I drove it. So I re timed it and it was good as new. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
