Engine Vibrations - Gearbox Mount?
TomsFocus
 Share
I don't think mine will be much different but we'll see.
Link to comment
Keep us posted mate.  Incidentally the lower mount was not too complex to change once the car was on ramps.  The only "issue" was there's a cast iron bracket attached to the exhaust that needs to be removed and you have to pry it a little to get it over the fixings (if you come to do the job you'll see what I mean).
Link to comment
Can you check the lower mount without removing it?
Link to comment
Unfortunately not, you can't see the rubber part until it's removed.   Having seen the state of mine I can't imagine that yours will be in much better condition, I'd suggest aiming to change it regardless once the weather warms up a bit.
Link to comment
So, the 'front' engine mount is now changed. Not too bad a job, apart from being freezing cold. Of the various youtube video's I'd watched (mostly US) do not show the various pipework that runs above the mount between the coolant tank and the engine. Which needs to be 'adjusted/loosened' to allow access to the engine mount bolts with a socket. And the four bolts holding it in are 'tight', so 6 point sockets 15/18mm. But, after a road test there is still a vibration/noise so looks like I'm going to be change the gearbox one.
I noticed that in your picture of the worn part, the original Ford item is a pressed steel looking item, whereas the replacement part sold by ECP/GSF is a slightly different looking design. Was your replacement identical to the original?
:smile:
Link to comment
:smile:
ECP didn't have Lemforder part in at the time, only some rather more crappy brands so I went elsewhere.  The Lemforder part was a but more "angular" in it's shape but it fitted nicely.
Link to comment
This style?
https://www.eurocarparts.com/ecp/c/Ford_Focus_1.8_2006/p/car-parts/transmission-parts/car-transmission/gearbox-linkage/?338590029&1&8024c98aaa16454dfa7f0f5a988b7a52dd3e474f&000482
Link to comment
6 minutes ago, wild_one said:
That's what the Lemforder one looked like, the original part was more rounded in shape.
Link to comment
So, the part you fitted to replace the worn item was similar in design to the one in my link?
Link to comment
Yup
  • Like 1
Link to comment
1 minute ago, 1979Damian said:
Yup
Stay tuned, because coming up soon will be a rear wheel bearing, fuel tank sender and the classic bonnet lock replacement!
Link to comment
I consider myself not too bad with the old tools but I couldn't possibly have got my original passenger side rear bearing (hub) off the car last year.  The bolts were so badly ceased they heads had to be cut off and access from the rear (to be bolts) is also a little awkward.
Link to comment
I know, it's a beast of a job. Shame because on the Mondeo rear wheel bearings which are very similar, the bolts go in from the outside so access is so much better.
  • Like 1
Link to comment
I watched a really good video on youtube by Autodoc and thought oh that shouldn't be too hard. Bought an SKF brand hub unit, took one look underneath and thought f*&k that! :taz:
Link to comment
I watched a really good video on youtube by Autodoc and thought oh that shouldn't be too hard. both an SKF brand hub unit, took one look underneath and thought f*&k that! :taz:
I was wondering if the bolts don't cooperate whether to attack the bearing retaining bolts with a grinder where they appear on the 'outside'
Link to comment
From what I understand the garage plasma cut the "heads" off the bots because they just stripped and wouldn't budge, even after a bit of heat.
Link to comment
heat and spiral/fluted extractors, never been let down on a focus yet lol.
  • Like 1
Link to comment
There's always dynamite to blast them out!
  • Haha 2
Link to comment
Tried it before, but my bodywork skills are not so great.
  • Haha 1
Link to comment
Who needs bodywork, just carry an umbrella?
  • Thanks 1
Link to comment
I might make MOT time a bit tricky though :tongue_smilie:
  • Haha 2
Link to comment
You’ll be amazed at the difference £20 in the cup holder makes :lol:
  • Haha 1
Link to comment
Just tell them it's a kit car?
  • Like 1
Link to comment
Anyway, I've now replaced the lower (rear) gearbox mount and I've still got a vibration so on to the last mount under the battery.
Going to have to wait a while though so stay tuned?
Oh, and I had a thought as to whether the noise is being caused by a loose plastic engine cover! Interesting?:dry:
Link to comment
  • 5 years later...
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
