penfold14 Posted October 28, 2017 Share Posted October 28, 2017 Cmax 2.0tdci 2011. Does anyone know where the fuel temp sensor is. The eml light has cone on, and codes flagged up Fuel temp circuit a intermittant, and fuel temp circuit b intermittant. I cleared the codes hoping it was a glitch, but they came back. Car appears to be running fine. Thanks Quote Link to comment Share on other sites More sharing options...
iantt Posted October 28, 2017 Share Posted October 28, 2017 its on the high pressure fuel pump, Quote Link to comment Share on other sites More sharing options...
penfold14 Posted October 28, 2017 Author Share Posted October 28, 2017 Excellent, glad its not in the tank. Don't suppose you have the finis code for the part? Do you have any pictures Quote Link to comment Share on other sites More sharing options...
iantt Posted October 28, 2017 Share Posted October 28, 2017 i would contact your ford dealer and they will use your reg number to find the correct finis number Quote Link to comment Share on other sites More sharing options...
penfold14 Posted October 28, 2017 Author Share Posted October 28, 2017 Is that the actual part?? Quote Link to comment Share on other sites More sharing options...
iantt Posted October 28, 2017 Share Posted October 28, 2017 no thats the pump , the temp sensor is the one with the green connection Quote Link to comment Share on other sites More sharing options...
penfold14 Posted October 28, 2017 Author Share Posted October 28, 2017 Thanks again. Found one online reasonably priced https://m.buycarparts.co.uk/delphi/7812317 Think its the right one Quote Link to comment Share on other sites More sharing options...
iantt Posted October 28, 2017 Share Posted October 28, 2017 i would locate the sensor, unplug it, and refit. clear codes and see if codes return Quote Link to comment Share on other sites More sharing options...
penfold14 Posted October 28, 2017 Author Share Posted October 28, 2017 Why is that mate.. If these are going to go, don't they just fail, unless you think it may be a dodgy wiring issue?? Quote Link to comment Share on other sites More sharing options...
penfold14 Posted November 1, 2017 Author Share Posted November 1, 2017 Light came back on in a matter of mins unfortunately. I have found the fuel pump, but which of these do you think is the right sensor. From the photo previously posted, and looking at the orientation, I would presume the lower one of the 2!! Quote Link to comment Share on other sites More sharing options...
penfold14 Posted November 25, 2017 Author Share Posted November 25, 2017 Well the garage I took it to reckoned the sensors I thought it was were fuel connections..... And said the sensor was under the hp pump. They would need to remove air filter housing, scuttle and boost control solenoid to replace. Does this sound right?????? Quote Link to comment Share on other sites More sharing options...
