ToXIcG Posted November 1, 2017 Share Posted November 1, 2017 Does anyone know if it is possible to use a sub woofer with this stereo. Quote Link to comment Share on other sites More sharing options...
cjay1 Posted November 1, 2017 Share Posted November 1, 2017 Yes but only if the sub has a high pass input as the radio dose not have a sub output. 1 Quote Link to comment Share on other sites More sharing options...
ToXIcG Posted November 1, 2017 Author Share Posted November 1, 2017 19 minutes ago, cjay1 said: Yes but only if the sub has a high pass input as the radio dose not have a sub output. Is speaker level input the same thing? Quote Link to comment Share on other sites More sharing options...
cjay1 Posted November 1, 2017 Share Posted November 1, 2017 1 hour ago, ToXIcG said: Is speaker level input the same thing? Yes all it does is allow you to tap into the factory speaker wiring 1 Quote Link to comment Share on other sites More sharing options...
AlexBartlam Posted November 2, 2017 Share Posted November 2, 2017 yes i had one on mine till i took it out last week, you have to splice the wires on the plug on the back with connector blocks, easy enough to do, dont run the power cable and the audio cables along the same door as it will interfere, i ran my rower from battery through the passenger side, then my audio wires from unit, through the drivers side. 1 Quote Link to comment Share on other sites More sharing options...
Rossyboi93 Posted November 3, 2017 Share Posted November 3, 2017 Do it as Alexbartlam has said I’ve also done mine like this 👌👌 1 Quote Link to comment Share on other sites More sharing options...
zain611 Posted November 3, 2017 Share Posted November 3, 2017 Just out of curiosity but how would you wire a sub for a mk6.5 fiesta? My dad has a small under seat sub which he took out his car. For some reason the remote stopped working which hopefully would be sorted by looking at the wiring. Just have to find the remote as it's been misplaced somewhere. Quote Link to comment Share on other sites More sharing options...
Rossyboi93 Posted November 5, 2017 Share Posted November 5, 2017 Same way mate. Just hook into speaker wire. Then have a remote wire there Along with the power wire. Then also plug in the audio cables 1 Quote Link to comment Share on other sites More sharing options...
