HOW TO: SYNC2 --> SYNC3 upgrade
what part numbers for sync 3 screen can i use focus cmax etc
  • 5 months later...
  • Replies 126
  • Views 140.3k
  • Phil21185
    Phil21185
    Yeah but with an ELM and this forum it's fairly easy to sort out!
  • @RevDan i would maybe suggest the opposite way  🙂 Copy your SYNC2 settings into SYNC3 and then in addition just rewrite one setting so you will have your sat nav active, first two values must be
  • @Bannko I did mine this weekend, I managed to brick the first unit I got after installing! It came with 2.2 software on it and I attempted to update it (downloaded an update from Ford for a similar sp
On 12/26/2020 at 11:44 PM, Fernan said:
Good day. I’ve upgraded from stock Sync Gen1 to Sync 3. But my parallel park assist seems not working properly. It says “cancelled by driver” when I try to use left turn signal to signify the intent to search on left side of the road instead of the default right side.
Below is my APIM:
7D0-01-01: #B##-####-#### (Parking sensor display enabled, FoE)
7D0-02-02: #3##-####-#### (Enabled flank guard)
7D0-04-02: ###8-## (Parking Assist Module type, Parallel Park Only, APA lite)
I haven’t updated the PAM yet. Should update the PAM?
My stock PDC sensors are 4 + 2 SAPP in the front and 3 in the rear.
Thanks.
Did you ever get to the bottom of this issue with the parallel park assist? Im having the same issue
