Hi, apologies if this has already been posted elsewhere in the site but I couldn't find this exact problem anywhere.
My rear light & side light is out on the nearside on my 2001 (pre-facelift) Focus (1.8 TDDI). I have changed both bulbs (the side-light was definitely blown but the rear did look ok) and have checked all the 10-amp fuses in the fusebox.
I have also swapped-round the common relay units in the fusebox to see if this helped, but nothing has worked.
Both dipped, main and brakes lights seem to work ok - seems odd to me that the brake lights work but one of the rear lights doesn't because they are housed in the same bulb, but then again I am not clued-up with electrics.
Any help much appreciated - thanks.
Rear & side lights out on one side
Started by olsam99, Aug 11 2008 02:09 PM
2 replies to this topic
#1
Posted 11 August 2008 - 02:09 PM
#2
Posted 11 August 2008 - 02:54 PM
side lights have seperate fuses to the brakelights(fuse74 - 15amp)
check fuse No53 - 7.5amp for the left side
check fuse No54 - 7.5amp for the right side bothe in the internal fusebox if this does not work there must be a wireing fault which requires further investigation
#3
Posted 11 August 2008 - 03:04 PM
thanks for the info mintalkin - i'll have a look tonight and do a follow-up post tomorrow. cheers
