SandyCat
Small Mk7 Door Card Mod
Quite a simple change, and yet it makes it look so much more elegant.
cool idea, this would e ncie in Red on the 2013 =)
That does look good! Think i will do that aswell! Do you have to take the door card off to get the grill off to paint ?
Thanks!
No need to take the card off as it's all moulded anyway-there is no separate grille.
I used a silver paint pen from a stationers to do the outer bit (although you can use silver model paint with a small brush if you are careful) then used a large marker pen for the black. Although I may go over it again with a gloss black which will look better.
You have to have a steady hand and take your time!
I have got used to it now and it just looks normal although it's a simple mod.
Could you possibly snap a close-up/closer picture please? ^_^
Thanks!
Ahh ok, i thought you had taken the grill off and spray painted it, and the same with the grill, that does sound a lot easier though!! Thanks :)
