fiestaguy Posted April 18, 2009 Share Posted April 18, 2009 Not sure if anyone else has had this problem or not, but my rubber trim lining the front windscreen is starting to fade. I can start to see white at the bottom of the trim. Any suggestions as to how to correct this? Is there some kind of polish that will help? Quote Link to comment Share on other sites More sharing options...
Russ Posted April 19, 2009 Share Posted April 19, 2009 Try either "back to black" trim polish or even a squirt of WD40 on a cloth and rubbed around it. Quote Link to comment Share on other sites More sharing options...
MichellefromEssex Posted April 19, 2009 Share Posted April 19, 2009 Not sure if anyone else has had this problem or not, but my rubber trim lining the front windscreen is starting to fade.I can start to see white at the bottom of the trim. Any suggestions as to how to correct this? Is there some kind of polish that will help? Inside or out? will speak to Max about it for you see what he suggest. Quote Link to comment Share on other sites More sharing options...
fiestaguy Posted April 19, 2009 Author Share Posted April 19, 2009 Its on the outside Quote Link to comment Share on other sites More sharing options...
SierraYankee99 Posted April 20, 2009 Share Posted April 20, 2009 Peanut butter, I jest you not. Its one of the best things for cleaning the rubber trims. Failing that, autoglym bumper care gel. Would never recommend back to black sprays, they are silicone based and dry the rubber out and after a couple of days will look worse than it did before. Quote Link to comment Share on other sites More sharing options...
Russ Posted April 20, 2009 Share Posted April 20, 2009 Depends what type of silicon spray you get, Silicon is a lubricant and not all sprays "dry out" It's actually the propellant in the cans that causes things to "dry out". Your right about the peanut, it's because of the oils within the nuts! Quote Link to comment Share on other sites More sharing options...
