Stepmg Posted February 14, 2014 Share Posted February 14, 2014 Artscot are those bulbs ones you have used? They dont look particularly good. Looks can be deceiving. Quote Link to comment Share on other sites More sharing options...
bry0586 Posted July 2, 2014 Share Posted July 2, 2014 just ordered some cree led sidelights, whats the process of changing them? is it just a matter of pulling old one out and new one in? Quote Link to comment Share on other sites More sharing options...
Jockstar Posted July 2, 2014 Author Share Posted July 2, 2014 Which ones did you buy? I bought one Cree 501 sidelight bulb, but it was far too big to fit into the headlight! Quote Link to comment Share on other sites More sharing options...
bry0586 Posted July 2, 2014 Share Posted July 2, 2014 These ones Sent from my GT-I8190N using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
Jockstar Posted July 2, 2014 Author Share Posted July 2, 2014 It should be a simple swap. Sometimes with LED lights, they won't work if you put them in the wrong way round. If that happens, just remove the bulb and rotate it 180 degrees and refit. Do you know how to remove the headlights to access the bulbs? Quote Link to comment Share on other sites More sharing options...
bry0586 Posted July 2, 2014 Share Posted July 2, 2014 ahh yeh ive fitted leds before and know the old180 switch, just not replaced any bulbs on front of the focus before Quote Link to comment Share on other sites More sharing options...
Jockstar Posted July 2, 2014 Author Share Posted July 2, 2014 You can't really get into the back of the headlights without removing them. It's also easier to replace the fog lamps by removing the headlights and sticking your hand down behind the front bumper. Saves marking the exterior trim. Headlights are held in with one bolt and plastic clips. Just got to be gentle with them. When you slide the headlight back in, your should hear the clips going back into place. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted July 2, 2014 Share Posted July 2, 2014 The headlights are a doddle to remove compared to other cars. I have got bulb changes down to less than 5 minutes now. Sent from my S5 1 Quote Link to comment Share on other sites More sharing options...
karlos1987 Posted July 2, 2014 Share Posted July 2, 2014 You can't really get into the back of the headlights without removing them. It's also easier to replace the fog lamps by removing the headlights and sticking your hand down behind the front bumper. Saves marking the exterior trim. Headlights are held in with one bolt and plastic clips. Just got to be gentle with them. When you slide the headlight back in, your should hear the clips going back into place. The fog lights I found easier to pull the trim out of the bumper then 2 screws holding the until in. Sent from my C5303 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
bry0586 Posted July 2, 2014 Share Posted July 2, 2014 done :D they fit but pretty tight compared to the normal sidelight bulbs, but theyre secure haha, tested before i put them back together, although passenger side i forget to put the cover back on so had to take it off again. i have to say it is easier than my past cars, my mg was a right pain in the bum to change, needed arms and hands like jack skellington haha. Quote Link to comment Share on other sites More sharing options...
Jockstar Posted July 2, 2014 Author Share Posted July 2, 2014 Good stuff! Quote Link to comment Share on other sites More sharing options...
troy45 Posted July 2, 2014 Share Posted July 2, 2014 I found when I put my LED's out of my first ST into the facelift sidelights I needed to cut some plastic back on the outside of the holder to let the bulb sit fully into the contacts - maybe potential for a poor connection otherwise. Quote Link to comment Share on other sites More sharing options...
PhillyFromTheWest Posted August 1, 2015 Share Posted August 1, 2015 I've got osram LEDriving 4000k for sidelights and footwells. They have a slight pink/purple tinge but not too bright and go well with standard headlights. Number plate, I got 6000k festoon bulbs, that give that more blue/white light like on BMWs. I wonder what 6000k side LEDs would be like, but think a bit too bright. I'd like a led reverse bulb, as standard too dull, but not sure what law is on that, so want something that's only but brighter. You can get osram rear indicator bulbs LED, but not found anyone selling em. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted August 1, 2015 Share Posted August 1, 2015 Get Cree reversing bulbs with led's around it. They are bright for reversing but also still reflect like standard bulbs. 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted August 1, 2015 Share Posted August 1, 2015 Get Cree reversing bulbs with led's around it. They are bright for reversing but also still reflect like standard bulbs. +1Cree 80W Reverse bulb 6000k Link: http://www.ebay.co.uk/itm/301487658232 1 Quote Link to comment Share on other sites More sharing options...
Kiwi Mark Posted August 2, 2015 Share Posted August 2, 2015 Hi folks, I replaced my dome light bulb with an led, which gives out loads more light but glows faintly when doors are shut and light switched off. Anyone else come across this? :( Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted August 2, 2015 Share Posted August 2, 2015 Yeah it's residual current, they go off after about 20 minutes normally 2 Quote Link to comment Share on other sites More sharing options...
Kiwi Mark Posted August 2, 2015 Share Posted August 2, 2015 Thanks for that! Back to the search for decent Cree reversing/fog lights now :) 2 Quote Link to comment Share on other sites More sharing options...
Farnaby87 Posted November 18, 2019 Share Posted November 18, 2019 Hi guys looking to get led sidelights for my focus MK2 just wondering if I need a conversion kit or anything as can't decide which are best to use? Quote Link to comment Share on other sites More sharing options...
