StanH Posted January 24, 2014 Share Posted January 24, 2014 One end of a supply pipe has blown off and I suspect it is a split or worn connector. The end indicated looks as if you just need to insert a small screwdriver to release. The other end looks as if it will be a simple push fit. Can anyone confirm that replacing this pipe is a straightforward sort of push and fit job, or do I need to have it done for me Thanks Quote Link to comment Share on other sites More sharing options...
StanH Posted January 24, 2014 Author Share Posted January 24, 2014 Posted due to a misunderstanding - apologies Stan Quote Link to comment Share on other sites More sharing options...
StanH Posted January 24, 2014 Author Share Posted January 24, 2014 Looks as if I should leave this one on, as no-one is looking at the other one. Can anyone tell me how to delete a topic? Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted January 24, 2014 Share Posted January 24, 2014 Done for you. Quote Link to comment Share on other sites More sharing options...
StanH Posted January 24, 2014 Author Share Posted January 24, 2014 Thanks, Stoney, now all I need is someone to respond to this one Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted January 24, 2014 Share Posted January 24, 2014 Looks like a clip off/on job to me. What is the pipe ando what does it connect to? Quote Link to comment Share on other sites More sharing options...
StanH Posted January 26, 2014 Author Share Posted January 26, 2014 It is a fuel supply pipe that runs from in front of the distributor to the rear. Took a chance and ordered a replacement pipe, and when I got it, it was self-evident what to do - in fact, the hardest part was paying for it- £46.45 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted January 27, 2014 Share Posted January 27, 2014 Glad you got it sorted. You usually find that once you have a new part in your hand, a good look at it usually helps you figure out how it goes on or comes off. Quote Link to comment Share on other sites More sharing options...
