Mudz Posted January 28, 2015 Share Posted January 28, 2015 Focus Mk 2.5 Titanium Hi all I recently bought a focus mk 2.5 1.8 petrol titanium. It has the Sony radio system but have only discovered that it does not have the bluetooth feature. Having read other thread I was wondering is it a case of buying a bluetooth module and plug and play? ( it seems as though there is a mic fitted where the interior light dome is however there is no voice command button on the remote stalk control) https://www.google.co.uk/search?q=ford+focus+sony+sound+system&client=ms-android-samsung&espv=1&source=lnms&tbm=isch&sboxchip=Images&sa=X&ei=bTTJVPqUBYKP7AbUuICABw&ved=0CAYQ_AUoAQ&biw=360&bih=567 (I'm hoping the above link shows the radio that I have) Also I changed the battery, and have lost the global closure function!! Any ideas? Any help appreciated Quote Link to comment Share on other sites More sharing options...
greggp Posted January 28, 2015 Share Posted January 28, 2015 Hi, there are various threads on here for your bluetooth question....not that easy I seem to recall but has been done. Regarding your global closing, because you disconnected battery, they need resetting, have you a handbook with the card, it explains how to do it in there... Its something like this Hold the switch down until the window is all the way down Release the switch then hold down again for 5 seconds Press the switch so the window goes all the way up Release the switch and press it up, again for 5 seconds The window will now be set for one touch and global opening/closing. Repeat this procedure for each individual window... Quote Link to comment Share on other sites More sharing options...
Mudz Posted January 29, 2015 Author Share Posted January 29, 2015 Thanks for the reply gregg, will try the windows when I get a chance! Quote Link to comment Share on other sites More sharing options...
Mudz Posted January 29, 2015 Author Share Posted January 29, 2015 Tried it, global closure working now! Thanks again.... Now for the bluetooth issue! 1 Quote Link to comment Share on other sites More sharing options...
