ash79 Posted December 11, 2009 Share Posted December 11, 2009 Hello i have a problem starting my fista 1.4 tdci, it turns over 2 or 3 times then stops i have to repeat this a number of times to start it in the morning. Any ideas??? Many thanks Ashley. Sorry i should have put in a few more details its a 53 plate with 69 000 miles. It also has a surge or sudden pull at around 2000 rpm this does not happen all the time usually when im gently excellerating, i have checked for fault codes and none are present, i was going to take the egr valve off tomorrow and clean it as i have read they can cause this problem. Thanks again Ashley Quote Link to comment Share on other sites More sharing options...
InstructorPiggy Posted December 11, 2009 Share Posted December 11, 2009 age? millage? Quote Link to comment Share on other sites More sharing options...
wellzy Posted December 11, 2009 Share Posted December 11, 2009 check injector seals mine had exact same problems cause 2 injector seals had gone and it's never missed a beat since. Quote Link to comment Share on other sites More sharing options...
InstructorPiggy Posted December 12, 2009 Share Posted December 12, 2009 check injector seals mine had exact same problems cause 2 injector seals had gone and it's never missed a beat since. highly likely :) Quote Link to comment Share on other sites More sharing options...
wellzy Posted December 12, 2009 Share Posted December 12, 2009 highly likely :) mirror image of what was wrong with mine, use to sit there for ages tryin to get it started. took about 10 trys before it would fire up sometimes i gave up and just nicked my dads x-trail :o :P as for surges again new seals would clear that up, mine hung back and all power would come in one go beofre repairs and now (even with 138,000 on the clock :o ) it feels like a new car. Quote Link to comment Share on other sites More sharing options...
ash79 Posted December 14, 2009 Author Share Posted December 14, 2009 mirror image of what was wrong with mine, use to sit there for ages tryin to get it started. took about 10 trys before it would fire up sometimes i gave up and just nicked my dads x-trail :o :Pas for surges again new seals would clear that up, mine hung back and all power would come in one go beofre repairs and now (even with 138,000 on the clock :o ) it feels like a new car. Thanks for your help, ive cleaned the egr valve and that made a differance to the surging but did nothing for the starting, if it was the injector seals would it stop the engine from turning over?? it will only turn over 2 or 3 times then stops or would this be the ecu telling it to stop?? did yours continue to turn over or did it stop like mine?? Cheers Ashley Quote Link to comment Share on other sites More sharing options...
wellzy Posted December 17, 2009 Share Posted December 17, 2009 Thanks for your help, ive cleaned the egr valve and that made a differance to the surging but did nothing for the starting, if it was the injector seals would it stop the engine from turning over?? it will only turn over 2 or 3 times then stops or would this be the ecu telling it to stop?? did yours continue to turn over or did it stop like mine?? Cheers Ashley mine stopped turning over after a few turn overs, it's the ecu stopping you burning out solinoids and over loading the motor. Quote Link to comment Share on other sites More sharing options...
