NeilRS
Speed camera recognition
10 posts in this topic
On my way to work there are 2 speed cameras- noticed today that both of them are marked on the sat nav with a exclamation mark in a red triangle. And also the sat nav said caution as I approached. Is this just coincidence or have we got speed camera recognition?
Not recognition, they are pre-programmed into the system.
The system won't notify you about mobile / newer cameras.
Jonro2009 likes this
Is this just a sync 3 function or does sync 2 do the same?
It may just be sync 3. I have sync 3 and it certainly does it. Your question llo2006 suggests you may have sync 2 and I would guess you haven't experienced this on your sat nav.
Mine has sync 2 and you certainly get an audible warning "caution", don't know if the sat nav displays a warning triangle as for me the audible warning is sufficient.
If you want coverage of all cameras mobile and fixed get a Snooper Elite
www.tomholroydphotography.co.uk
I have Sync 2 and get the warning triangle. The "caution" message freaked me out until I worked out what it meant. I've now turned it off...
Stoney871 likes this
I only activate the verbal warning if I'm in an unfamiliar place.
Pity they don't have the ability to select a tone warning instead of the voice.
I have sync 2 and I've never had a warning before, where is it in the options so I can see if I can enable it?
