Mk3 Prefacelift Sync 2 8" touchscreen upgrade, How to guide with pics!!!
@Luke_Anderson
Thanks for the swift response this morning,:thumbup: as you can see from the picture I have had quite a good day today.😊 I have noticed from the setting that it has already picked up my cars VIN # where did it get that from? And will it be a problem when I get round to updating Sync as it on version 2.3 and I will need to put in the donor cars VIN # to update it.
One other thing on the back of the ACM there are 2 Fakra connectors a Black and a White I know one is for the GPS antenna on the roof, which one is which and what is the second one for?
  • Replies 1.4k
  • Views 400.3k
  • Luke_Anderson
    Luke_Anderson
    Cub and baba? And you think I’m the one that needs to grow up 😂 you see petal, the problem with people like you is that you expect things to be done for you, you don’t want to invest the time or effor
  • Nathan Buffery
    Nathan Buffery
    The easiest place to take the MS can is from the heater module. If I remember rightly it's the blue plug.  Pin 18 grey & orange on the heater module goes to pin 16 on the sync module.  P
  • Luke_Anderson
    Luke_Anderson
    Thanks! If anyone has any questions I’m more than happy to help!  It took me 10 hours to do but that was with some figuring out along the way, I reckon if I was to do it again I could do it in ha
It pulls the vin from your bcm module, I used my donor cars vin to update and it works fine 👍🏻
The black and white fakras are dab and fm antennas, the gps is the blue fakra that goes to the apim
That’s fantastic work. Would love to tackle something like this but I’m one of those that’ll.
not only brick the car but break it too 😂😂😂
You’d be amazed at how resilient these cars are, When I was working this all out there was a lot of trial and error, especially with the coding side of things. It’s actually quite hard to break it permanently! I think everyone should try doing things at least once, you might surprise yourself!
@Luke_Anderson Hello again.
OK today I got on the Fun Part as you describe it; I used Forscan and wrote the ***** Built Data from a 2018 Focus ST3 same as mine but newer, all seemed to work fine as when I cycled the ignition the splash screen had change from Ford to ST Performance.
Next I moved on to FoCCCus  to make the changes as in your write up lines 125, 154, 157,172 all OK.
But line 123 has only 2 entries in it NOT SET and UNKNOWN both show up as 00?
Next line 214 this line only has 08 entries available so could only enter the 09 value?
Can you give me any guidance on this one?
Thanks again Rog
On 3/15/2019 at 9:54 PM, andspenka said:
I have one, but the wiring is for a Kuga. I am not sure if it's exactly the same but I'm sure it could be adapted. Let me know if you're interested.
Do you still have the media hub and loom for the kuga ? as I am in need, just about to take the plunge and upgrade my kuga from sync 1 to sync 3
I saw this!!! Crafty or what! Couldn’t believe it hahahaha.
Sent from my iPhone using Tapatalk Pro
or maybe its this one they buy
https://www.amazon.co.uk/ZIZON-Camera-Connector-Extension-Harness/dp/B07G2B1WCC/ref=sr_1_1?keywords=B07G2B1WCC&qid=1554909977&s=gateway&sr=8-1
Yes I do, I have the one with the 2 x USB, SD card slot and line in on it. Comes with the full centre console wiring loom.
Hi everyone
my first post 😉
I have been looking into doing this myself just read this topic and forgive me if i have missed this, but has anyone tried to do this with manual heater controls as my heaters don't have the blue connector to add the GPS wires to 😞
Any help would be great
14 hours ago, Zetec prdro said:
Hi everyone
my first post 😉
In this scenario you can either find another pair of ms-can wires or just run a pair of wires Up to the gpsm module and tap into it there
In the Kuga, the GPS module is behind the Speedo, you can see the metal bracket held in with the screw, the module is attached to that. This is where I tapped in to the wires.
On the back of the apim why do some modules have 2 mini usb input (white and black plug) and some only have the one (black) what are they both for ?
Hey everybody ✌️
I did the Sync 3 upgrade in my 2011 Focus Titanium.
Everything works except two (very irritating things 😞
1: Emergancy call, whenever I start my car it says “Emergancy call fault, please contact your dealer for service...
1a) HOW can I fix this problem! It’s driving me crazy 😕
2) voice control, when music is played it doesn’t work, if I turn off audio (by pressing the button in the rotary knob) it works but it’s muted no audio....
2a): how do I fix this?
Do any of you have similar problem?
***Every wire has been checked and is working/good***
AHU is from previous radio and not a new from sync 3 car
So you are using your original sync 1 audio module?
Yeah mate
I’d probably start by swapping that out for a sync 3 one
Just tried swapping my audio unit with a sync 3 one and it didn’t work.. 😞 it still did it. Wondering if i need to configure something in FORScan/Focccus
Have you done the focccus programming yet?
Yeah every thing just like you Said mate 😕
Odd, was it defiantly sync you upgraded from?
Upgraded from a Non SYNC to SYNC 3
I’m assuming that the issue is going to be in that then, hopefully some coding can sort it out!  How was the upgrade from non sync?
Happy days!!!!
Emergancy assist now works!!!!
Have been listening to “Emergancy call fault, please contact you dealer for service” for six months!!!
Had to code the RCM to enable Emergancy calls!
6 months ago I bought a plug and play conversion harness everything worked perfectly except for I now have to find out why voice control doesn’t work with music on.
The upgrade from non sync to sync 3 was easy the coding was same as yours
