theroninhunter Posted June 22, 2018 Author Share Posted June 22, 2018 1 hour ago, Phil21185 said: Well to be honest I only enabled the repeater as I like seeing more gadgets and gizmos! I don't use it and more often than not, the climate is on single anyway. Quick question, do you have nav on yours and if so, is the repeater in the main cluster out by a factor of 256?! When the 8" says there's a mile to go to the next turning, the cluster says 256. It's almost as if the APIM is sending the data to the cluster but transposed one byte to the right! (Or left, depending on Fords significant bit policy lol) I've not noticed tbh, Assuming "Cluster" is the little LCD between the odometers. Quote Link to comment Share on other sites More sharing options...
gillyallan Posted June 22, 2018 Share Posted June 22, 2018 Can UK sync screens be enabled to control climate or is a physical connection missing?Also what's this about single and dual mode? Can this be done on mine?I do have dual controls just not via Sync. Quote Link to comment Share on other sites More sharing options...
gillyallan Posted June 22, 2018 Share Posted June 22, 2018 Jeez just figured the dual and single mode by holding auto. Didn't realise this. Quote Link to comment Share on other sites More sharing options...
Phil21185 Posted June 22, 2018 Share Posted June 22, 2018 Yes I mean in the dash gauges. If you turn the passenger temp dial it will unlink from the driver's temp. Yes they can be configured using forscan and modifying the APIM data, but as we are discovering there appears to be a bug with it... Quote Link to comment Share on other sites More sharing options...
gillyallan Posted June 22, 2018 Share Posted June 22, 2018 Wonder why they feel we in UK don't want it in sync screen so disable it. If i asked a Ford dealer to enable it. Would they entertain it? Quote Link to comment Share on other sites More sharing options...
theroninhunter Posted June 22, 2018 Author Share Posted June 22, 2018 17 minutes ago, gillyallan said: Wonder why they feel we in UK don't want it in sync screen so disable it. If i asked a Ford dealer to enable it. Would they entertain it? Depends on the garage, mine didn't want to touch APIM data with a barge pole. Quote Link to comment Share on other sites More sharing options...
Phil21185 Posted June 22, 2018 Share Posted June 22, 2018 1 hour ago, gillyallan said: Wonder why they feel we in UK don't want it in sync screen so disable it. If i asked a Ford dealer to enable it. Would they entertain it? Easy to do with an ELM cable and Forscan... Quote Link to comment Share on other sites More sharing options...
gillyallan Posted June 22, 2018 Share Posted June 22, 2018 So original poster and others who have noticed this issue. Did your cars come with climate enabled or did you enable yourself. If its yourself. Do you think this is why it was disabled from Ford as they knew there was an issue with right hand drives. Quote Link to comment Share on other sites More sharing options...
Phil21185 Posted June 22, 2018 Share Posted June 22, 2018 In my case I upgraded to Sync 3. I'm hoping to get some time to play in the car tonight and see what's what 🙂 Quote Link to comment Share on other sites More sharing options...
mastachaz Posted June 23, 2018 Share Posted June 23, 2018 i think only people with sync 3 upgarde have this problem rest of them dont have it on screen. Quote Link to comment Share on other sites More sharing options...
Botus Posted June 23, 2018 Share Posted June 23, 2018 so as I suggested it sounds like a bug ford never fixed on RHD cars so turned off the display as they are lazy? Quote Link to comment Share on other sites More sharing options...
gillyallan Posted June 23, 2018 Share Posted June 23, 2018 so as I suggested it sounds like a bug ford never fixed on RHD cars so turned off the display as they are lazy?Crap ain't it?Same with map updates. Sell you built in sat nav then never update it. Try to now promote using 3rd party map via waze. Quote Link to comment Share on other sites More sharing options...
Alex.S Posted January 10, 2020 Share Posted January 10, 2020 This threads old to say the least , my friends got a 2016 mondeo vignale. It’s got climate option on sync. I’m not sure if that’s sync 2 or 3 but I don’t have climate on my 2020 focus sync3. Having watched the Ford sync3 video I’m not surprised they binned it. Over complicated. The right hand drive theory might be a factor but I’m happy with the current set up. Quote Link to comment Share on other sites More sharing options...
simrad Posted May 24, 2020 Share Posted May 24, 2020 Hi all, On mine the the A/C indicator is wrong. Everything works OK but when A/C is deactivated on dashboard on screen shows is ON, and when on dashboard is OFF on screen shows it's ON. Don't know if anyone has this issue and how to solve 🙂 Quote Link to comment Share on other sites More sharing options...
unofix Posted March 22, 2021 Share Posted March 22, 2021 I hate to ask after all this time but did anyone get this to work correctly, and can it be done on a Focus Mk4 ? Quote Link to comment Share on other sites More sharing options...
colinmcg71 Posted March 23, 2021 Share Posted March 23, 2021 I have enabled the climate screen on Sync 3.4 on my Mk4 Focus and dual mode works as it should. Passenger and driver side dials control the correct side and display correctly on screen. All other functions work too, power on/off, A/C on/off, Recirculate, MaxA/C, Max Demist etc. Only the heated rear screen button is greyed out. Quote Link to comment Share on other sites More sharing options...
JPW Posted March 23, 2021 Share Posted March 23, 2021 On the MK3/3.5 it's still reversed and no way to change. The system is hardcoded to a left hand drive. Not sure about MK4... Was it factory or retrofitted? Quote Link to comment Share on other sites More sharing options...
colinmcg71 Posted March 23, 2021 Share Posted March 23, 2021 Update. Heated rear screen button working with engine running. Climate can be controlled with voice commands. Quote Link to comment Share on other sites More sharing options...
karlbbb Posted March 27, 2021 Share Posted March 27, 2021 On 3/23/2021 at 5:23 PM, JPW said: On the MK3/3.5 it's still reversed and no way to change. The system is hardcoded to a left hand drive. Not sure about MK4... Was it factory or retrofitted? Funny you mention that. My Mk3.5 sometimes (once every three months or so) switches to LHD mode. I can tell this has happened because the temperature on both sides switches to 22ºC (I'm always on 20ºC both sides), and the passenger side becomes the "lead" knob, meaning changing the passenger side also changes the driver side, and using the driver side knob splits the temperature zones. I have to turn off the engine again, open the door, wait for the Ford logo to disappear from the Sync screen, then start the car again and it's usually fixed. I don't have it on the Sync screen, never plugged in a cable etc, I'm just talking about normal stock climate here. Very odd. Quote Link to comment Share on other sites More sharing options...
Alex.S Posted March 28, 2021 Share Posted March 28, 2021 On 3/27/2021 at 11:41 AM, karlbbb said: Funny you mention that. My Mk3.5 sometimes (once every three months or so) switches to LHD mode. I can tell this has happened because the temperature on both sides switches to 22ºC (I'm always on 20ºC both sides), and the passenger side becomes the "lead" knob, meaning changing the passenger side also changes the driver side, and using the driver side knob splits the temperature zones. I have to turn off the engine again, open the door, wait for the Ford logo to disappear from the Sync screen, then start the car again and it's usually fixed. I don't have it on the Sync screen, never plugged in a cable etc, I'm just talking about normal stock climate here. Very odd. If the rest of the world would just drive on the correct side of the road.... Personally I don’t see the point in it , you can’t be distracted by the screen like that while driving so it’s pointless. Quote Link to comment Share on other sites More sharing options...
