Claire1234 Posted November 6, 2018 Share Posted November 6, 2018 Hi there聽 Will the small size Diskloc fit on a ST-Line X please as the steering wheel is square at the bottom if you know what I mean? Is there any extra security you would recommend ? Just trying to make a new car as safe as it can be. It has keyless start but not the extra payable spec of keyless entry. thanks Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted November 6, 2018 Share Posted November 6, 2018 In all honesty I doubt someone would try and steal a ST-Line when I'm sure there's an ST around the corner that's just as easy to get into. Relocating the OBD2 port and fitting a dummy is very common so might be worth a look. You can wire the dummy to show all the cars info etc. on the computer, but it won't be able to start the car or do anything useful to the ECU. Quote Link to comment Share on other sites More sharing options...
Tiexen Posted November 6, 2018 Share Posted November 6, 2018 1 minute ago, Luke4efc said: In all honesty I doubt someone would try and steal a ST-Line when I'm sure there's an ST around the corner that's just as easy to get into. Relocating the OBD2 port and fitting a dummy is very common so might be worth a look. You can wire the dummy to show all the cars info etc. on the computer, but it won't be able to start the car or do anything useful to the ECU. With the new model Fiesta the OBD port is disabled if the alarm goes off. Quote Link to comment Share on other sites More sharing options...
Claire1234 Posted November 6, 2018 Author Share Posted November 6, 2018 Thanks I鈥檒l look into that. Just worried as it will be parked on the road. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted November 7, 2018 Share Posted November 7, 2018 I use a clutch pedal lock.Stops the car being started or driven.Sent from my SM-G965F (S9+) Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted November 7, 2018 Share Posted November 7, 2018 https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F112199649054Sent from my SM-G965F (S9+) Quote Link to comment Share on other sites More sharing options...
Frembrit Posted November 7, 2018 Share Posted November 7, 2018 I can't see why it wouldn't fit. Just pop in to a Halfords and ask to try one. The Small fits my Mondeo steering wheel, although it was initially a bit tight when closed on to the steering wheel spokes, so I聽聽widened the casing and now it fits fine. However, I've had this one for 15 years so I don't know if the current ones are the same. 聽 Quote Link to comment Share on other sites More sharing options...
Claire1234 Posted November 7, 2018 Author Share Posted November 7, 2018 Thanks both I鈥檒l look at clutch lock also聽 Quote Link to comment Share on other sites More sharing options...
Claire1234 Posted November 7, 2018 Author Share Posted November 7, 2018 Stoplock pro looks like another option that isn鈥檛 as big ? Quote Link to comment Share on other sites More sharing options...
karl46 Posted November 7, 2018 Share Posted November 7, 2018 I ha a disc lok, pain to keep putting on and off and off course storage when off. I now use a Stoplok Pro, much more convenient and can be used to fend off car jackers. Quote Link to comment Share on other sites More sharing options...
Frembrit Posted November 7, 2018 Share Posted November 7, 2018 Indeed it is a pain. I聽only use it now when I'm out and about in聽places around the country like if I drive to a gig聽in another city then I'll use it or if I go to the cinema (Theives know you'll be in there for 2 -3 hours and someone had their TXS stolen whe he was watching a film) Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted November 7, 2018 Share Posted November 7, 2018 13 hours ago, Luke4efc said: In all honesty I doubt someone would try and steal a ST-Line when I'm sure there's an ST around the corner that's just as easy to get into. Sadly this isn't the case any more, ST-Lines are getting stolen quite often now, even those without keyless entry!聽 Tbh it's made me more worried about buying a facelift Focus TX.聽 I'd wrongly assumed it was only ST's getting stolen and I really can't be bothered fitting steering or clutch locks every time I park.聽 Also, in my case, my neighbour does fit a steering wheel lock to his ST so mine would be the easier target at home lol! I would be doing the OBD lock if/when I get one but don't want the hassle and inconvenience of physical locks. Quote Link to comment Share on other sites More sharing options...
Claire1234 Posted November 7, 2018 Author Share Posted November 7, 2018 Do I need the OBD thingy even if it鈥檚 not keyless entry , just keyless start ? Sorry I鈥檓 not very techie. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted November 7, 2018 Share Posted November 7, 2018 22 minutes ago, Claire1234 said: Do I need the OBD thingy even if it鈥檚 not keyless entry , just keyless start ? Sorry I鈥檓 not very techie. Yeah, it's the OBD port that's physically used to switch off the alarm and start the car once in, it's nothing to do with the keyless entry. 聽 However Tiexen said above the new Fiesta already comes with an OBD blocker if the alarm goes off.聽 So that would suggest you don't need another one.聽 But having said that, if they can get in without setting the alarm off (by cloning the key signal when you lock or unlock the car), the alarm wouldn't go off which may render the standard system useless.聽 I'd want to know more information on the standard system personally. 聽 Quote Link to comment Share on other sites More sharing options...
zain611 Posted November 7, 2018 Share Posted November 7, 2018 1 hour ago, TomsFocus said: Sadly this isn't the case any more, ST-Lines are getting stolen quite often now, even those without keyless entry!聽 Tbh it's made me more worried about buying a facelift Focus TX.聽 I'd wrongly assumed it was only ST's getting stolen and I really can't be bothered fitting steering or clutch locks every time I park.聽 Also, in my case, my neighbour does fit a steering wheel lock to his ST so mine would be the easier target at home lol! I would be doing the OBD lock if/when I get one but don't want the hassle and inconvenience of physical locks. Why not get a steering wheel lock? Or you could do the Mr bean move of taking off the steering wheel all together 馃槀. With the amount of crime rising in London it might be worth getting a lock myself but because I normally park in public car parks and on the drive that probably deters a thief.聽 If the thief isn't dumb enough to break in and hotwire the car without realising at the last moment there's no steering wheel.聽 Quote Link to comment Share on other sites More sharing options...
Claire1234 Posted November 7, 2018 Author Share Posted November 7, 2018 Thanks all again for your input....now the removable steering wheel, we actually have a motorhome and the steering wheel comes off as you drop the bed down over the seats and swivel seats in day , my husband thinks it鈥檚 the best anti theft device going. 2 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted November 7, 2018 Share Posted November 7, 2018 6 hours ago, zain611 said: Why not get a steering wheel lock? Or you could do the Mr bean move of taking off the steering wheel all together 馃槀. With the amount of crime rising in London it might be worth getting a lock myself but because I normally park in public car parks and on the drive that probably deters a thief.聽 If the thief isn't dumb enough to break in and hotwire the car without realising at the last moment there's no steering wheel.聽 Honestly... laziness, the very reason we have central locking and now keyless start & entry lol!聽 I tend to be in a rush for the loo when I get home, no time to mess around with a steering lock tbh.聽 When out I want a quick get in & away, and even park in the easiest space to get out of... We fitted a quick release boss to my mates track car though...he now takes his wheel with him exactly like Mr Bean! 1 Quote Link to comment Share on other sites More sharing options...
TimST2 Posted November 8, 2018 Share Posted November 8, 2018 I haven't used a steering wheel lock since my first car (a 1988 Peugeot 205)! Much neater to disable the OBD port (data link connector fuse in the manual) and get a window sticker if it's really that much of an issue. That's what I've done on my ST. Sent from my SM-G900F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Freddy42 Posted November 27, 2018 Share Posted November 27, 2018 A fuel cut-off switch is a good investment.聽 Your friendly auto tech will fit one for about 拢50. While rummaging in the scrap box the other day, I found a piggy-back fuse and thought it might do the trick, fitted in the fuel pump fuse in the passenger well.聽 The 20A fuse is fitted in the piggy line and the return from the switch soldered to one pin of a fuse which has been made open-circuit.聽 Seems too simple? Quote Link to comment Share on other sites More sharing options...
MarksST Posted November 30, 2018 Share Posted November 30, 2018 On 8 November 2018 at 7:56 AM, TimST2 said: I haven't used a steering wheel lock since my first car (a 1988 Peugeot 205)! Much neater to disable the OBD port (data link connector fuse in the manual) and get a window sticker if it's really that much of an issue. That's what I've done on my ST. 聽 聽 Sent from my SM-G900F using Tapatalk 聽 聽 You protected a now 30 years old pug better than a 2 year old car that gets stolen regularly? pulling the fuse might not work if their unit is self powering. Quote Link to comment Share on other sites More sharing options...
MarksST Posted November 30, 2018 Share Posted November 30, 2018 On 7 November 2018 at 1:33 PM, zain611 said: Why not get a steering wheel lock? Or you could do the Mr bean move of taking off the steering wheel all together 馃槀. With the amount of crime rising in London it might be worth getting a lock myself but because I normally park in public car parks and on the drive that probably deters a thief.聽 If the thief isn't dumb enough to break in and hotwire the car without realising at the last moment there's no steering wheel.聽 Cars don't get stolen from people's driveways or public car parks? 1 Quote Link to comment Share on other sites More sharing options...
MarksST Posted November 30, 2018 Share Posted November 30, 2018 On 27 November 2018 at 3:21 PM, Freddy42 said: A fuel cut-off switch is a good investment.聽 Your friendly auto tech will fit one for about 拢50. While rummaging in the scrap box the other day, I found a piggy-back fuse and thought it might do the trick, fitted in the fuel pump fuse in the passenger well.聽 The 20A fuse is fitted in the piggy line and the return from the switch soldered to one pin of a fuse which has been made open-circuit.聽 Seems too simple? What happens if you pull that out, take the 20A fuse out and put the fuse back into the fusebox? Quote Link to comment Share on other sites More sharing options...
TimST2 Posted November 30, 2018 Share Posted November 30, 2018 聽 12 minutes ago, MarksST said: You protected a now 30 years old pug better than a 2 year old car that gets stolen regularly? It wasn't 30 years old at the time! It also had no immobiliser or alarm and could be broken into using a plastic spoon聽馃槀 And it was the 90s - steering wheel locks were all the rage back then... Sent from my SM-G900F using Tapatalk 聽 聽 Quote Link to comment Share on other sites More sharing options...
MarksST Posted November 30, 2018 Share Posted November 30, 2018 Fiestas get stolen just as easily now. Quote Link to comment Share on other sites More sharing options...
TimST2 Posted December 1, 2018 Share Posted December 1, 2018 As I understand it, my ST-2 can only be stolen by breaking the window (keyless start not keyless entry) and plugging a laptop into the OBD port. So while the thieves try to work out how to re-enable the OBD port the alarm will be going off. Removing the fuse is only one method of disabling the port.聽Sent from my SM-G900F using Tapatalk聽聽聽聽聽聽 Quote Link to comment Share on other sites More sharing options...
