Mk8 Fiesta Mods
21 minutes ago, DEVSR2 said:
Any pics of the shark fin? That's on my list too. Be good to see if you do go for the spoiler tip mate, they look good online but haven't seen a real pic as of yet @OllyY
  • Replies 50
  • Views 92.3k
  • Hammerite smooth is great for calipers, always use it on my cars Did my Leon this weekend -
  • Decals, splitter, footwell lights, upgraded headlight bulbs, focus engine cover - all keep the warranty valid 🙂
  • Darren-mk8
    Darren-mk8
    Not done much so far. I also went for the footwell lights. Got mine from CEUK. I've painted my calipers, added a bit of red pinstripe. Badge overlays. A couple of decals. Tyre lettering. Got loads mor
Thanks @OllyY - that looks cracking ! Any drop in DAB signal?
I had a shorter aerial on my other mk8 and DAB dropped all of the time
I couldn't tell you on the DAB signal as I can't stand radio, Spotify only for me. Although I have read in other forums/review pages that others haven't noticed any difference. Paintmodz also say that they haven'y had any reports regarding signal issues. They definitely look a lot better, fairly cheap and easy to install.
1 minute ago, OllyY said:
I couldn't tell you on the DAB signal as I can't stand radio, Spotify only for me. Although I have read in other forums/review pages that others haven't noticed any difference. They definitely look a lot better, fairly cheap and easy to install.
Sorry mate, i've wasted your time. I've just gone on to order from paintmodz and seen this.. Typical
Mk3 Ford Focus / Mk8 Ford Fiesta 'Shark Fin' Aerial (Painted / Hydrodipped)
If you have a mk8 Fiesta then the shark fin will definitely fit. That picture isn't the base on the UK Fiesta mk8
On 7/13/2019 at 2:56 PM, DG97 said:
Do you have any more side shots of your car? Really like the thought/look of the red calipers but could do with seeing a bit more as I'm super tempted to get mine painted.
Not a great one but here you go.
Perfect, it’s a nice subtle look tbh
time for me to get some decent caliper paint and crack on!
qgFeakI.jpg?1
which specific maxton splitter version is that bud? Is it the V2?
im not sure which one to go for and yours looks great
TRC  🙂
  • 3 months later...
https://flic.kr/p/2hJvsjn
Hi
I have an st line x and wanted to have it remap’d but wanted to have the option to remove the map before services.  Is a Superchips bluefin the only option.  I have seen race chip GTS (piggy back chip) but cannot find much info about them.
My mods to date are European mk8 black edition vinyls.
Red rim protectors (dealer fitted)
LED fog lamps upgrade from CEUK to match the colour of my all LED headlamps.
https://www.carenhancementsuk.co.uk/collections/mk8-fiesta/products/enhanced-edition-led-h8-11-fog-unit
Thanks.
  • 4 months later...
What are your thoughts on this exhaust tip i installed?
It’s a good choice, nice fit and makes the back end more distinct, mind if I ask where that’s from? Might fit one of those myself...
What is the difference to the one that comes fitted as standard to the STlineX ? I am presuming here, you have removed one to fit one.
Unless that car is a non X St line and they don't have them fitted as standard?
I will have to find the link for the exhaust tip from ebay. I did have to modify it slighty to fit . If u look at the standard st line exhaust it has an exhaust tip as standard which is welded on but with a bit of cutting to the bigger exhaust tip from ebay it fits nice. I will post some pics soon of what i did and whats required to make it fit. I just think the back if the st line is abit too standard looking for me
https://www.ebay.co.uk/itm/151567238918
Link for exhaust tip, from the photo u can see i cut out 2 long strips of metal which enables the strap clamp to go around outside and pulls exhaust tighter. Please note you need to order a 70-80mm clamp from ebay aswell as its required for the modification. If u look at ur standard exhaust u will see a metal nip at the bottom that sticks out.the cutting of the exhaust tip with help slide it along the standard exhaust nip.
Photo shows smaller clamp that is supplied with exhaust tip and the larger one required for modification
Photo shows how exhaust tip slides on and the metal nib i was talking about
Haven't seen anything about tech, did sync 3 retrofit, reversing camera, front/rear sensors and speakers/subwoofer. I know there's people here with insane sub setups, would love to see them
  • 1 month later...
I just installed mountune primary,secondary hoses,turbo hard pipe and k&n panel filter. Anybody have any thoughts on the sound difference or performance gains. Mines definitely got more dump valve kinda noise. Don't see how the turbo hard pipes can make much difference as the diameter of the pipe is the same as the plastic standard one.
  • 3 months later...
Anyone have a titanium version of the fiesta (5 door) ? I just got a black one and really want to change up it’s styling not too fussed about engine mods yet
@Darren-mk8 your car looks amazing
I have a Mk8 Titanium 5 door magnetic. So far have fitted shark fin aerial, battery cover and fusebox cover, all from Paintmodz. If you go for the shark fin aerial make sure you select right one, there are two different types. Also mud flaps and Climair wind deflectors. Bonnet lifting struts as well. Surprising how useful these are when you don't have to use the support strut. I have also fitted an engine cover but this takes a lot of trimming to fit.
  • 5 months later...
Bit late to the party. But can I ask how you removed your original infotainment system?
  • 1 month later...
It seems my car is gonna have such one as seen on the pic here in Belgium, so no shark fin for me I guess
