Larkspeed_NL Posted June 11, 2019 Share Posted June 11, 2019 This is driving me nuts and I can't figure it out. I have a 2002 Focus Estate and it refuses to unlock with the keyfob. The truck release works fine and it will lock the doors no problem but I have to unlock it with the key. I have replaced the battery in the keyfob and I have tested the button using a multimeter so the button itself is working correctly and closing the circuit like it should. I can't seem to get the car to go into programming mode either, no matter how many times I turn the ignition on and off rapidly I get no beep to say it's going into programming mode, it did this fine when I got the car. Any ideas? Quote Link to comment Share on other sites More sharing options...
williamweb Posted June 11, 2019 Share Posted June 11, 2019 18 minutes ago, Larkspeed_NL said: This is driving me nuts and I can't figure it out. I have a 2002 Focus Estate and it refuses to unlock with the keyfob. The truck release works fine and it will lock the doors no problem but I have to unlock it with the key. I have replaced the battery in the keyfob and I have tested the button using a multimeter so the button itself is working correctly and closing the circuit like it should. I can't seem to get the car to go into programming mode either, no matter how many times I turn the ignition on and off rapidly I get no beep to say it's going into programming mode, it did this fine when I got the car. Any ideas? How many keys ? Quote Link to comment Share on other sites More sharing options...
Larkspeed_NL Posted June 11, 2019 Author Share Posted June 11, 2019 I only have the one key Quote Link to comment Share on other sites More sharing options...
williamweb Posted June 11, 2019 Share Posted June 11, 2019 9 minutes ago, Larkspeed_NL said: I only have the one key You can only program with two keys. Quote Link to comment Share on other sites More sharing options...
williamweb Posted June 11, 2019 Share Posted June 11, 2019 I know the immobiliser is separate from the remote locking but you said you tried programming with one key. Quote Link to comment Share on other sites More sharing options...
Larkspeed_NL Posted June 11, 2019 Author Share Posted June 11, 2019 4 minutes ago, williamweb said: I know the immobiliser is separate from the remote locking but you said you tried programming with one key. yes and for getting the central locking to work it worked fine with just one key when I first got the car, since then it has decided to stop locking and now like I said it won't even enter programming mode so the number of keys is kind of moot. Quote Link to comment Share on other sites More sharing options...
williamweb Posted June 11, 2019 Share Posted June 11, 2019 13 minutes ago, Larkspeed_NL said: yes and for getting the central locking to work it worked fine with just one key when I first got the car, since then it has decided to stop locking and now like I said it won't even enter programming mode so the number of keys is kind of moot. So you are saying that the remote can be reprogrammed with one key? Quote Link to comment Share on other sites More sharing options...
Larkspeed_NL Posted June 11, 2019 Author Share Posted June 11, 2019 18 minutes ago, williamweb said: So you are saying that the remote can be reprogrammed with one key? Yes. Originally when I got the car the fob battery was dead, I put in a new battery but the fob didn't work and then I followed the procedure I found on the net to put the car into programming mode and pushed the button on the fob... the car beeped to accept the input from the fob and then as instructed I turned the ignition back on to exit programming mode and the fob worked as it was supposed to for about 3 months. After 3 months it stopped responding to the unlock button, like i said before the lock button and the trunk release both work fine and the physical button itself tests as working properly. But now any attempt to put the car back into programming mode fails and the car never enters programming mode so I can't just try and rebind the key with the car. Quote Link to comment Share on other sites More sharing options...
williamweb Posted June 11, 2019 Share Posted June 11, 2019 4 minutes ago, Larkspeed_NL said: Yes. Originally when I got the car the fob battery was dead, I put in a new battery but the fob didn't work and then I followed the procedure I found on the net to put the car into programming mode and pushed the button on the fob... the car beeped to accept the input from the fob and then as instructed I turned the ignition back on to exit programming mode and the fob worked as it was supposed to for about 3 months. After 3 months it stopped responding to the unlock button, like i said before the lock button and the trunk release both work fine and the physical button itself tests as working properly. But now any attempt to put the car back into programming mode fails and the car never enters programming mode so I can't just try and rebind the key with the car. If you have the owners handbook the correct programming procedure is included. Quote Link to comment Share on other sites More sharing options...
Larkspeed_NL Posted June 11, 2019 Author Share Posted June 11, 2019 1 minute ago, williamweb said: If you have the owners handbook the correct programming procedure is included. Like I said I have already followed the programming procedure and the car will not enter programming mode. Quote Link to comment Share on other sites More sharing options...
williamweb Posted June 11, 2019 Share Posted June 11, 2019 3 minutes ago, Larkspeed_NL said: Like I said I have already followed the programming procedure and the car will not enter programming mode. Sometimes on the internet the information is incorrect that’s why I referred you to the owners handbook.In the handbook you require two keys. Quote Link to comment Share on other sites More sharing options...
williamweb Posted June 11, 2019 Share Posted June 11, 2019 16 minutes ago, williamweb said: Sometimes on the internet the information is incorrect that’s why I referred you to the owners handbook.In the handbook you require two keys. You said it worked with one key nevertheless it’s always good practice to have a spare,saved me a lot of expense and inconvenience Quote Link to comment Share on other sites More sharing options...
williamweb Posted June 11, 2019 Share Posted June 11, 2019 34 minutes ago, Larkspeed_NL said: Like I said I have already followed the programming procedure and the car will not enter programming mode. So just had a look in my handbook and there is a re- programming the unlocking function 👍 Quote Link to comment Share on other sites More sharing options...
